Closed Thread
Old 05-16-2011, 03:28 PM
rediknik rediknik is offline
Junior Member
Default motorcycle powered
Does anyone know of any build logs or other information on building a kart with a motorcycle engine? I was considering buying a 250 ninja motor and putting it on my old coyote race frame. any help is greatly appreciated.
Old 05-16-2011, 03:43 PM
gokart14's Avatar
gokart14 gokart14 is offline
go to the search part in the forum and type in motorcycle engine will find somthen
Obstacles don't have to stop you. If you run into a wall, don't turn around and give up. Figure out how to climb it, go through it, or work around it. ~ Michael Jordan
Old 05-16-2011, 04:37 PM
anderkart's Avatar
anderkart anderkart is offline
Quote:
Yeah, here ya go man:--> http://www.diygokarts.com/vb/showthread.php?t=4742
Old 05-16-2011, 05:46 PM
Doc Sprocket's Avatar
LOTS!!!
I'm doing a 250 Virago transplant myself...
Old 05-16-2011, 06:25 PM
Junior Member
How much power do you think a single mcp caliper with slotted rotor can handle? Do you think i would need front brake system for 20-30hp or 40-50hp?
Old 05-16-2011, 06:29 PM
What's the caliper and rotor off of? What's the HP spec on the engine?
  #7
Old 05-16-2011, 11:45 PM
Junior Member
Race kart brakes the brand is Mcp. Motor will be either 175cc 15hp or 250cc 35hp
  #8
Old 05-17-2011, 06:22 AM
I don't know enough about those brakes to be able to comment. At this point I would say use them and let your initial shakedown runs determine their suitability. Perhaps some others will weigh in on this, but I personally would be a bit doubtful about using "kart" brakes on a potentially heavy and fast machine.
Closed Thread
