Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Closed Thread
Old 04-19-2011, 10:44 AM
j.concepcion54321's Avatar
j.concepcion54321 j.concepcion54321 is offline
Rebuilding KTM, Need Kart
Default How to bleed disk brakes
is this hard to do?? Do you need special tools to do so?? Pics/ vids would be helpful.
Thanks,
Josh
The Following User Says Thank You to j.concepcion54321 For This Useful Post:
dictionary6767 (11-05-2012)
Old 04-19-2011, 03:22 PM
devino246's Avatar
devino246 devino246 is offline
Official DIYGK Chem Nerd
Youtube has tons of videos on how to to this. Its easy, and you dont need any special tools.
http://www.youtube.com/results?searc...sc+brakes&aq=f
ASE Certified
Old 04-19-2011, 11:25 PM
Rustydog2010's Avatar
Rustydog2010 Rustydog2010 is offline
NZ Nutta :|
Depends, do you have someone to help you?
Jeremy.
I weld naked, for an all over tan!
Old 04-20-2011, 07:02 AM
i can probably get my brother or my dad to help
Old 04-20-2011, 09:29 AM
devino246's Avatar
From another thread:
Quote:
Originally Posted by devino246 View Post
Heres how i was taught to do it.
Your going to need a helper to pump the brakes. You'll need a bucket to catch the brake fluid. There should be a little bleed screw on the caliper.
Have your helper apply pressure to the brake pedal and open the bleed screw. Brake fluid will squirt out along with little bursts of air. Close the screw and tell your helper to let off the brake pedal. Your helper MUST keep their foot on the pedal while the bleed screw is open. If they let off it'll suck in air. Repeat this until only fluid squirts out.
ASE Certified
The Following User Says Thank You to devino246 For This Useful Post:
j.concepcion54321 (04-20-2011)
Old 04-20-2011, 12:28 PM
do i have too add fluid afterwards??
  #7
Old 04-20-2011, 12:54 PM
devino246's Avatar
Quote:
Fill it before you start and check it afterwards, you'll probably need to add some.
ASE Certified
  #8
Old 04-20-2011, 02:05 PM
what do i put in? water??
  #9
Old 04-20-2011, 02:19 PM
devino246's Avatar
No no no no no no. Brake fluid, the top of the reservoir should say what type(DOT3, DOT4, or DOT5). Use only what it tells you to use, the wrong type of fluid can eat through rubber components.
ASE Certified
  #10
Old 04-20-2011, 07:29 PM
ok thanks.
  #11
Old 04-25-2011, 01:28 PM
the bleed screw isnt coming out of the brake thingy
  #12
Old 04-25-2011, 02:23 PM
ok i got the screws out but then i realized that they didnt have anything inn them. one of them squirted out a little bit when i did the process listed above, and the other one didnt it just sputtered out air. i think im missing the brake fluid. how do i know what type to use?? and were doo i put it in??
Please reply quickly i wanna ride me kart! LOL
  #13
Old 04-25-2011, 02:32 PM
devino246's Avatar
You dont have to remove the screws completely, they should 'open' with a turn or so. Look on the master cylinder for the type to use. Posting a pic of your master cylinder & brake caliper would help.
ASE Certified
  #14
Old 04-25-2011, 04:06 PM
ok. my dad had some dot 3 in the shed so i just used that. i poured it into the little box where the pedal connects to, and where on the other side the two brake lines go out to the brakes. i noticed the reason that the brakes werent working. one of the fitting thingies that is used to p;pump the fluid was cracked so air and brake fluiod would get out through there and thats why it woulddnt get to the brakes. my cameras not working so i cant take the pics. i hope to get that fixed.
  #15
Old 04-25-2011, 04:07 PM
oh and the brake calipers and the master cylinder both say mcp on them
  #16
Old 04-25-2011, 04:09 PM
this is the master cylinder i have
http://image.dhgate.com/upload/spide...z0152209_0.jpg
  #17
Old 04-26-2011, 08:48 AM
didnt get any pictures but i got a little video of my problem...
http://s1205.photobucket.com/albums/...rrent=Josh.mp4
  #18
Old 04-26-2011, 02:44 PM
devino246's Avatar
That rubber piece shouldnt keep it from working.
ASE Certified
  #19
Old 04-26-2011, 03:05 PM
what do you think the problem is then?? im almost positive its the rubber piece
  #20
Old 04-26-2011, 03:08 PM
devino246's Avatar
You really need to understand on a basic level how this thing works. Googling "master cylinder" would be a good idea.
Pumping it without lines attached wont do anything. Google "bench bleeding"
ASE Certified
Closed Thread
