Go Back   DIY Go Kart Forum > Announcements & Suggestions > FAQ & Articles
Reply
Old 03-15-2011, 04:32 PM
slowcart slowcart is offline
Junior Member
Default converting to live axle
hey guys im pretty new to the go kart seen. posted up but lost my acc when the site went down in dec. i have a two seater go kart that is one wheel drive. i am planning to convert it to live axle since it will see more dirt then road. just wanna get some ideas on how to go about it.. will post pics of the kart this week
Old 03-15-2011, 06:30 PM
toystory_4wd's Avatar
toystory_4wd toystory_4wd is offline
You can start by looking at pics of live axle karts, that should give you a pretty good idea to begin with. You will need to get an axleshaft (keyed shafting), bearings and hangars to match, hubs for both rear wheels, hubs for the sprocket and brake, new rear rims to match the hubs, and probably a few things that aren't coming to me ATM.
You will need to cut away the old axle tube and all related parts. You will likely have to do some cutting and welding on your frame to create suitable bearing mount locations. There's a pretty good chance you may have to alter your motor mounts and/or jackshaft mounts to locate them appropriately.
You will need to work out how to mount your brake again, likely having purchased a new one.
It's less simple than this, but it oughta give you some food for thought.
Old 03-15-2011, 06:42 PM
Junior Member
i been looking at alot of pictures i found axles,bearing hangers and all the good stuff. just trying to figure out what keeps the axxle from moving side to side, as for the brake i would be using a disk break from northen tools or tht type
Old 03-15-2011, 07:07 PM
devino246's Avatar
devino246 devino246 is offline
Official DIYGK Chem Nerd
Quote:
There are 2 set screws on each bearing that keep it from sliding.
Are you talking about those posi-brakes??
ASE Certification (Engine Repair, Brakes, Electrical, Engine Performance), pending
Old 03-15-2011, 07:08 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
usually the bearings attached to the hangars have set screws. if not locking collars help, but in most cases the wheel hub is right up against the wheel bearings on each side, allowing no play back and forth.
Old 03-15-2011, 07:10 PM
Junior Member
i was looking and thinking on going the pillow bearing way
  #7
Old 03-15-2011, 07:12 PM
i have never tried the 2 bolt pillow blocks, but i ordered these from surplus center, it was in total $14 plus shipping it was $21-22.
i havent had time to set them up but well see how it goes, harder to mount than pillow blocks but half the price.
  #8
Old 03-15-2011, 07:14 PM
Junior Member
i was looking at those too.
  #9
Old 03-15-2011, 07:17 PM
im yet to see how they work, might be able to get the kart rolling this weekend, but i still need money for paint and then i ordered clutch and chain yesterday.
could be a month until i can tell you how they work.
  #10
Old 03-15-2011, 10:51 PM
Rustydog2010's Avatar
Rustydog2010 Rustydog2010 is offline
NZ Nutta :|
I had two of those on my old Sidewinder buggy. Plenty strong enough for that application, that was with a 500cc MB engine.
Jeremy.
I weld naked, for an all over tan!
  #11
Old 03-19-2011, 03:30 PM
jim454's Avatar
jim454 jim454 is offline
Junior Member
Make sure to use loctite on the set screw's.They sometime's loosen up from vibration.
  #12
Old 03-19-2011, 04:30 PM
dave1701's Avatar
dave1701 dave1701 is offline
Good for 100,000 Miles
I decided I was going to convert my kart to a live axle last year, but I'm still nowhere closer to the setup. Oh well.
  #13
Old 04-06-2011, 07:39 PM
Junior Member
ight i picked up a couple of rear tires from a ride on mower. im havin issues tryin to find a axle for them. the wheels r 3/4" and the i need a axle over 42" . i looked at a few site and cant find much in that size
Reply
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
