Go Back   DIY Go Kart Forum > Building Plans And Advice > Using Tools and Welding
Old 02-13-2020, 09:57 AM
cretella8348 cretella8348 is offline
Default Nut Removal
I was able to remove the 4 lugs. Any tricks or tips on this 1.5" center nut so I can replace the live axles? Thanks!!!
Old 02-13-2020, 10:02 AM
itsid's Avatar
itsid itsid is offline
same thing actually
penetrating oil, patience, gentle application of heat
and/or a few taps with a hammer to start cracks in the brittle rust..
more penetrating oil and more patience
and a few uggaduggas later it'll be removed.
Old 02-13-2020, 11:19 AM
Karts of Kaos's Avatar
Karts of Kaos Karts of Kaos is offline
here is the urban dictionary definition of uggadugga https://www.urbandictionary.com/defi...m=ugga%20dugga
if it ain't broke I'll take it apart and fix it
Old 02-13-2020, 11:44 AM
Whitetrashrocker's Avatar
Whitetrashrocker Whitetrashrocker is offline
The title is just begging for Poboy.
Old 02-14-2020, 12:57 AM
landuse's Avatar
landuse landuse is online now
So true
Old 02-14-2020, 10:38 AM
mckutzy mckutzy is offline
Heat.. keep the torch moving...
Old 02-14-2020, 01:30 PM
Kartorbust's Avatar
Small propane torch or oxygen fuel will help or a breaker bar with a cheaper pipe on that. Just need yo hold it steady. PB blaster or the like will help loosen it up. An impact gun (air or electric) will help.
