Old 02-12-2020, 08:05 PM
Walter Keller Walter Keller is offline
Default Baja triple tree bearings ?
Baja steering head bearings look like the same used in bicycles ......true or false . I need a set for a build we are doing. Who stocks them?
We too are also replacing the front forks with a set of the larger diameter 28" long ones from gopowersports - welding on clamps to the existing steering head for the larger dia full length forks.
Old 02-12-2020, 11:18 PM
mckutzy mckutzy is offline
As long as you keep it tight and well lubricated, it should be fine...
I'm surprised it had bearings..
I used a good set I found, cleaned the cups and re lubed caged race...
Works great..
Old 02-13-2020, 06:46 AM
Default mb200 steering head bearings
Found all the parts here -
https://www.vmcchineseparts.com/prod...b200-mini-bike
