  #21
Old 07-17-2011, 04:07 PM
T-man's Avatar
T-man T-man is offline
hey blaz , for some reason the video responces is only showing the "identification " video. when I click on "video responces" " see all" it then showes up. might be some glitch. I want the new one to show up on the video page so I'm going to deleat it and you can then re submit it . hope fully it shows up then. sound good.
http://www.tmanskarts.com & 1 Primary youtube channel T-mans Go Karts
  #22
Old 07-17-2011, 04:54 PM
Blazkowiez's Avatar
Blazkowiez Blazkowiez is offline
Kart Aficionado
k, we'll try that I suppose.
gokartrepair.com. Family owned and operated in Houston for 40 years. Parts-Service-Advice
  #23
Old 07-17-2011, 08:55 PM
B man's Avatar
B man B man is offline
Tecumseh FTW!
WOW thinks Blaz. my max-torque weight assembly was screwed up. so it only engaged at a higher rpm. i thought that was why it was jumpy. turns out it was that little piece you said had to slide easily through the clutch. cleaned it up. no jolts or jumpiness. still engages only at a high rpm,but it does so ALOT more smoothly.
If it doesn't work......well then its gonna!
  #24
Old 07-17-2011, 11:42 PM
bighead's Avatar
bighead bighead is offline
Okay I just went over my clutch really good. I got it all cleaned and back as a working unit.
The pin/guide that the weights slide on came lose from the weights. The pin came out some stoping the clutch/weights from closing. I just taped them back down flush. I hope it works.
Blaze have you seen the pins slide out? Can you use a china 30 series primary with a comet 30 series driven?
My clutch was filthy.
Attention Criminals!! This is a defense free crime zone. All law-abiding citizens have been disarmed for your convenience.
  #25
Old 07-18-2011, 12:03 AM
Blazkowiez's Avatar
Kart Aficionado
We've had the pins come out in some of the packs, its not always the end, sometimes you have to drive the pins back into the pack in an attempt to make it last or grind the end of the pin if its worn. If it keeps coming out you may need to purchase a new weight pack which isn't terrible versus a whole clutch but at least it comes with new springs too. Its rare for a pin to slide out but it does happen.
I'm glad to hear its helping some people. We'll try to shoot some more of various things and throw it up, editing took forever and really makes me not want to do more than one video a week.
  #26
Old 07-18-2011, 03:52 PM
Blazkowiez's Avatar
Kart Aficionado
Tire video!
The audio was poor but it shows how to change the tire decently enough.
The Following User Says Thank You to Blazkowiez For This Useful Post:
bighead (07-19-2011)
  #27
Old 07-18-2011, 05:55 PM
wall gator's Avatar
wall gator wall gator is offline
Good vid......kinda scarry with thoes JACK STANDS!!!!!!!! Thought he was gonna lose it for a minute.....
"DON'T BLAME ME,,,I'VE GOT BUDHIMERS"
  #28
Old 07-18-2011, 06:13 PM
Blazkowiez's Avatar
Kart Aficionado
Heh, Rob likes to manhandle tires a bit. The jackstands are super stable though, we made them that height using old Yerf-Dog wheels we cut off karts.
  #29
Old 07-18-2011, 06:32 PM
B man's Avatar
Tecumseh FTW!
why was that tire so worn? isn't it the drive tire that wears first?
Edit: or did it have slicks?
  #30
Old 07-18-2011, 06:43 PM
Blazkowiez's Avatar
Kart Aficionado
The tires were slicks and they wanted turf tread.
  #31
Old 07-18-2011, 07:45 PM
Doc Sprocket's Avatar
Good, informative videos. Thanks, and keep up the good work.
  #32
Old 07-18-2011, 11:23 PM
Wim's Avatar
Wim Wim is offline
Jazz Maverick
Great stuff! He makes tires look easy.
I just did two myself, good fun.
  #33
Old 07-19-2011, 05:45 PM
Blazkowiez's Avatar
Kart Aficionado
Was that kinda what ya'll wanted real quick about the belts?
The Following 2 Users Say Thank You to Blazkowiez For This Useful Post:
bighead (07-19-2011), wall gator (07-19-2011)
  #34
Old 07-19-2011, 06:22 PM
T-man's Avatar
**** ya thats great, good use of video annotations.
  #35
Old 07-19-2011, 07:21 PM
wall gator's Avatar
KEEP the vid's coming.....ya'll doin better and better(production), TAV'S are one of mt favaorite subject's.....WALT
  #36
Old 07-19-2011, 07:29 PM
bighead's Avatar
Originally Posted by Blazkowiez View Post
Tire video!
He makes it look so easy. This would take me about 20 minutes per tire.
  #37
Old 07-19-2011, 08:59 PM
Blazkowiez's Avatar
Kart Aficionado
You think thats crazy, I'll try and get a video of him changing a car tire with just screwdrivers... its sickening.
  #38
Old 07-19-2011, 09:06 PM
redsox985's Avatar
redsox985 redsox985 is offline
^^^ Let's see the Tire Whisperer do his finest!
  #39
Old 07-19-2011, 09:41 PM
Blazkowiez's Avatar
Kart Aficionado
Explaining tire sizes, and we got a little wacky this time but the information is solid.
  #40
Old 07-19-2011, 09:45 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
haha you definately know your stuff.
