Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Reply
Old 11-28-2019, 02:14 PM
4WDKarts 4WDKarts is offline
4WD Karts
Default 4WD Kart Build Pics
Hello to all who are interested. After several months delay we finally have pics of one of our 5th generation 4WD Karts. This is mostly the front differential and inner & outer spindles. You will also see some linkage with clevises and tie rod ends. This will end up controlling the lock-out front axle and drive shaft lock-out. We are still waiting on the remainder of the lock-out mechanism parts from the machine shop.
We will have more pics next week of the rear portion of the Kart.
Thanks
Old 11-28-2019, 04:45 PM
Kartorbust's Avatar
Kartorbust Kartorbust is online now
Not bad, I do like what I see. After how you explained it, it definitely looks how I had imagined it would. I could see how it could also be done with independent suspension, just will be more complicated, but could be done with custom portal axles if more height is needed.
Old 11-28-2019, 05:42 PM
itsid's Avatar
itsid itsid is offline
looks like you already broke one spindle bracket..
Anyways, do you want to enter this years build off contest?
In that case: please create a pile pic according to the rules,
else: this is the wrong forum and this thread will need to get merged/moved
let me know
Old 11-28-2019, 06:27 PM
4WD Karts
You better get some glasses!. Nothing is broke!.
I'll send you what you need.
Old 11-28-2019, 06:49 PM
itsid's Avatar
Well that
Click image for larger version
looks like a crack to me
Old 11-28-2019, 06:56 PM
4WD Karts
Yep, you need glasses. That is a space between moving parts. I need to take your job here on the DIY Forum, you don't know what your doing. Don't reply until you get smarter.
  #7
Old 11-28-2019, 07:13 PM
itsid's Avatar
Yep, you need glasses. That is a space between moving parts. ...
Ah a positive stop... hmmkay
but
still looks cracked from that angle
  #8
Old 11-28-2019, 07:14 PM
JTSpeedDemon's Avatar
2019 Build Off Winner!
Ehhh, kinda looks like a crack to me. But you're the one building it, so I'll take your word for it.
It could also be a stray Sharpie mark.
Currently Flathead-Crazed
  #9
Old 11-28-2019, 07:17 PM
4WD Karts
You can shove it pal! Go crack off somewhere else. Even when people show you pics you still don't believe it. Sorry you feel that way. Good luck!
  #10
Old 11-28-2019, 07:19 PM
itsid's Avatar
Quote:
Originally Posted by JTSpeedDemon View Post
Ehhh, kinda looks like a crack to me...
at least I'm not hallucinating
You will very quickly need to adjust your way of communicating around here..
Noone said it is broken or cracked.. I only said it looks like it is..
(a bad lighting on a handmade unchamfered cut can cause an irregular reflection ...)
as long as it's fine.. it'll be .. it still looks cracked at first glance.
and that's not our fault at all!
If you cannot stand any commenting,
then maybe a forum is not the right place for you at all!
If you do not want to read such,
then you might need a better camera,
or clean your edges up nicer before taking a picture.
In any case you need to stop raging at every comment or you'll have a very hard
(and likely SHORT!) time around!
The Following 3 Users Say Thank You to itsid For This Useful Post:
Functional Artist (11-29-2019), Joe-405 (12-14-2019), pearl111 (12-16-2019)
  #11
Old 11-28-2019, 07:23 PM
4WD Karts
Yeah you are seeing a REAL 4WD GO-KART. Did you ever think you'd ever see one? Kinda cool isn't it?
  #12
Old 11-28-2019, 07:30 PM
itsid's Avatar
a 4wd kart is indeed cool..
but that is NOT the first I see I'm afraid
not even the first posted on diygokarts
  #13
Old 11-28-2019, 11:14 PM
landuse's Avatar
landuse landuse is offline
For some reason itsid is being unusually lenient with you. I would have given you a temporary holiday by now for talking like that. One more snarky comment, and you truly will be gone.
The Following 2 Users Say Thank You to landuse For This Useful Post:
Functional Artist (11-29-2019), Kartorbust (11-29-2019)
  #14
Old 11-29-2019, 09:36 AM
Functional Artist's Avatar
Functional Artist Functional Artist is offline
Even if not cracked (yet) IMO the design & construction of those "spindles" don't look Heavy Duty enough for the dynamic stresses that can/will be applied
...especially by a 4 x 4 kart (off road terrain + big tires)
* But, at least he's actually posted some pics, of his ideas, this time
RESISTANCE IS FUTILE
  #15
Old 11-29-2019, 09:57 AM
Kartorbust's Avatar
If this works well, I may do something similar in V2 of my future build. But as mentioned before, independent suspension and not a stiff frame.
  #16
Old 11-29-2019, 10:18 AM
Tpdingo Tpdingo is offline
Yeah looking back your right. I think my cheapo chinese kart has thicker metal on the spindle holders. One good push into that suspension and the wheels might fall off.
I'd seriously recommend stress testing those parts you made and not just saying "you don't know what your doing its good" because that might be the last time you say that if you do...and I'm not talking about getting banned.
Give a wrench long enough and WD-40, and I can remove the world's rusty bolts.
  #17
Old 11-29-2019, 12:06 PM
Kartorbust's Avatar
Well one could say you'd end up being banned from an air addiction lol. Most are built with 3/16" and upwards of 1/4" thick. Making another one the same way and stress testing it could tell you what you need to know. But as long as you feel your work is holding up, that's up to you.
  #18
Old 12-13-2019, 04:29 AM
itsid's Avatar
.. well since this thread does not fullfill the requirements for entering the build contest,
it's now moved.
  #19
Old 12-14-2019, 02:38 PM
Deadbeef Deadbeef is offline
I'm gonna be that guy, that is not a diff in the front it's a spinco gearbox.......
  #20
Old 12-14-2019, 03:21 PM
Quote:
**** your right. Given that, why drift with two wheels slipping when you can with 4 wheels slipping ?
Reply
