Reply
Old 10-14-2019, 01:19 PM
Fakart Fakart is offline
Junior Member
Default 583cc 2 stroke shifter kart
Any ideas on how I should mount the engine or reinforce the frame or what size axle to use??? Itís a fa kart victory frame 42/ch/11. And a 583 Rotax 2 stroke (snowmobile engine).
Old 10-14-2019, 01:32 PM
JTSpeedDemon's Avatar
2019 Build Off Winner!
Let's see some pics of what you're working with...
Currently Flathead-Crazed
Old 10-14-2019, 07:30 PM
Junior Member
---------- Post added at 06:21 PM ---------- Previous post was at 06:20 PM ----------
I’m not having a whole lot of luck posting pictures on here, it asks for a url rather than letting me go to my gallery and the url doesent pull up the picture it makes a white box... oof
---------- Post added at 06:24 PM ---------- Previous post was at 06:21 PM ----------
http://http://www.2040-parts.com/_co...447093/001.jpg
---------- Post added at 06:25 PM ---------- Previous post was at 06:24 PM ----------
http://www.2040-parts.com/ski-doo-mx...lock-i1447093/
---------- Post added at 06:27 PM ---------- Previous post was at 06:25 PM ----------
And this is the frame https://cometkartsales.com/OTK-FA-Vi...-SKU20818.html
---------- Post added at 06:30 PM ---------- Previous post was at 06:27 PM ----------
All I have is the frame though, no axle or steering components. It’s a sturdy frame, no rust I believe it’s from 2014.
Old 10-14-2019, 10:21 PM
Smerft85 Smerft85 is offline
With that much spunk I'd want a cage around me and harnesses, I'm planning an artic cat 580 in my large frame dingo, but I'll likely have to go "buggy" status with it and do a full suspension, at least...
Old 10-15-2019, 12:49 AM
landuse's Avatar
landuse landuse is offline
Quote:
Iím not having a whole lot of luck posting pictures on here, it asks for a url rather than letting me go to my gallery and the url doesent pull up the picture it makes a white box... oof
All I have is the frame though, no axle or steering components. Itís a sturdy frame, no rust I believe itís from 2014.
Click on "Go Advanced", then click on manage attachments. You can either enter url's or upload pics from gallery.
Old 10-15-2019, 08:05 AM
Junior Member
Default Cage
I am planning on welding a roll bar over the top of my head, just a u roll bar with some supports. It will also help with radiator placement so they get good airflow. Place one radiator on either side of me. Its normally a long radiator that goes above the tracks of the snowmobile but I'm gonna make it a 2 radiator system somehow. I'll have the proper safety precaution. I'm just worried about the over all strength of the frame and axle to the power of that engine. I dont know what size axle I should get and what kind of frame reinforcements will be needed?
  #7
Old 10-15-2019, 12:31 PM
Double radiators wouldn't be hard, but why? I'd run one radiator with an electric fan, less plumbing and parts to replace later on down the line. When I said roll cage, I meant a roll hoop isn't going to help much, if you gear it correctly you are very capable of 80+ mph, unless you reinforce everything from the ground up, and do a full cage for structure and weight, I think you are begging for trouble! Even 1" live axles have been bent, unless you use some sort of cv shaft as an axle from a car, even then you may twist the axle, frame, yourself ect. As much as I dislikecarsandcameras on youtube, check out their crosskart, might shed some light on what you have to look forward to, I doubt this will be a cheap build to say the least! Not to mention the small fortune you will spend on tires at $200 a set on average. Your frame doesn't have the overall size to accommodate the clutch from the snow machine either from what I can see.
Reply
