Reply
Old 10-08-2019, 01:38 PM
Default Mikuni/Chikuni Carb sizing
Need some advice on carb sizing. I have a few 212s. Id like to upgrade the carbs.
I have one VM22 in hand.
2 of the engines have small cams, 10.75:1 compression and ported:polished heads, and 32 degrees timing. Will the 22mm be appropriate for this or do I need a 24mm? What is the best way to determine the needs?
I also am building a 301 and donít know what to use carb wise either.
Thanks
Reply
