Reply
Old 10-05-2019, 05:31 PM
hochimin hochimin is offline
Junior Member
Default Split rim broke - need to replace
Had a scare when the wheel went flying off the kart today! Sheared leaving the inner hub/bearing on the kart and the wheel rolling away.
Any suggestions to replace? Theyíre split rim and maybe thatís not a good idea. 3/4Ē inside diameter with 15x5-6 tires.
Looks like I can replace the inner part of the split rim but I donít know what itís called so am having a hard time finding that part.
Old 10-05-2019, 09:29 PM
Dingocat's Avatar
Dingocat Dingocat is offline
Broke
Weld it back on?
Did it with a cheap wagon wheel. Then scrapped it.
Current Manco hoarder
Old 10-05-2019, 10:35 PM
BigWes's Avatar
BigWes BigWes is online now
I can't tell by looking at your picture but are you suggesting that your hub came apart?
If that is the case, deflate the tube and remove the wheel halves from the hub and just buy a new hub. I personally suggest replacement over trying to repair a busted hub. Just my opinion.
But surely someone will come along and disagree with me just because it was me that said it...
Check out any of the go kart sites and they should have one...
This ain't rocket science boys!!!
Reply
