Reply
Old 09-23-2019, 08:44 PM
5814SpeedCo 5814SpeedCo is offline
Default Overhaul on the Carter Brothers 2435 continues
After riding the kart for a little bit I decided to tear it back down and throw some color on it. Let my daughter pick the color, Sunburst Yellow.
Need to touch up the wheels and I have some perforated sheet metal that I'm going to make a guard at the front that wraps underneath.
Old 09-24-2019, 05:26 AM
Budget GoKart's Avatar
Budget GoKart Budget GoKart is offline
Aka a kenbar
Nice paint job
quotes from me: I didnt do it. i broke it!
Old 09-24-2019, 07:26 PM
Got the tie rods back on and almost finished the front end and realized I never trimmed up the steering arms. Also want to get some new shiny hardware for it. Have to get some new bolts for the steering wheel as well. Over all though I'm definitely liking how it's turning out.
Old 09-25-2019, 12:48 AM
landuse's Avatar
landuse landuse is offline
Looking good!
Old 09-25-2019, 03:40 PM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
Quote:
Nice deluxe heim joints.
I like your spindle steering arms--they're offset to fit inside/with the rims. You'd obviously have a tire rubbing issue without them. Are they custom?
What's your spindle axle length and the size of your front rims and tires? I'm kind of asking on behalf of throttleman who's having fitment issues. See this thread: http://www.diygokarts.com/vb/showthread.php?t=42091
Old 09-25-2019, 04:45 PM
Cut off the old arms and welded on some step out arms to clear the tires.
The Following User Says Thank You to 5814SpeedCo For This Useful Post:
Hellion (10-30-2019)
  #7
Old 09-28-2019, 09:24 AM
The original pedals were to far gone to restore so I have a set from a Manco that I'll be setting up. The brake lever will need a spring to pull it back into place once depressed. After that they will get paint and maybe something out on them for grip.
  #8
Old 10-17-2019, 07:04 PM
Been ripping around on the kart but decided that it needs some assistance with driving at night so.....I am adding a 12" LED light bar to the front. It looks pretty tough and will definitely light up the road.
  #9
Old 10-30-2019, 01:45 PM
Hellion's Avatar
I’m often repeating this but those pedals are interchangeable left and right—the best way is have them arching away from you and they’ll provide a foot rest as well in that orientation.
So the right pedal should be rotated 180 degrees and mounted on the left (as the brake), and do the same with the left pedal turning it into the gas pedal. Way more comfortable in my estimation. Just a thought.
  #10
Old 10-30-2019, 02:17 PM
If I had the pedals as you suggest, the left tire would be rubbing on the pedal at full left turn. Plus my daughter is only 7 and wouldn't be able to reach the pedals.
  #11
Old 10-30-2019, 02:42 PM
Hellion's Avatar
Check again, the pedals have the same offset whether facing towards you or away. No rubbing should occur. But....your mileage may vary.
I didn’t know your daughter was 7.
Reply
