Reply
  #41
Old 09-26-2019, 11:28 AM
Randy H Randy H is offline
https://www.blocklayer.com/degree-wheel.aspx
Check here.
Custom degree wheels.
The bigger the better until it becomes impractical.
This might work.
The Following User Says Thank You to Randy H For This Useful Post:
JTSpeedDemon (09-26-2019)
  #42
Old 09-26-2019, 11:39 AM
JTSpeedDemon's Avatar
Currently flathead-crazed
Anyone know the cam specs for a stock flathead?
Local Bird Engineering Nut
  #43
Old 09-26-2019, 12:30 PM
Flyinhillbilly's Avatar
Flyinhillbilly Flyinhillbilly is online now
The great cornholio
Quote:
Not a clue, but with a dial indicator and a degree wheel you can find out what they are. The degree wheel is handy for setting timing. I use mine on every engine that I build.
You can't drink all day if you don't start in the morning
The Following User Says Thank You to Flyinhillbilly For This Useful Post:
Randy H (09-26-2019)
  #44
Old 09-26-2019, 01:55 PM
wenee9w wenee9w is online now
Just any old degree wheel will work as long as it's the same diameter or bigger that the flywheel?
360 degrees is 360 degrees weather on a small degree wheel or a large one I can read.
The Following User Says Thank You to wenee9w For This Useful Post:
Reply
