Reply
Old 09-23-2019, 01:49 AM
Default Coleman CT200u-EX Flywheel upgrade?
Hey guys. I’m modding the factory 196 on the Coleman. I want to keep the 196 because of its lighting coils. I was pondering upgrading the flywheel but I do not know if there is a billet piece that is compatible with the lighting coils. Anyone know if there is a flywheel available or am I stuck with the stock flywheel?
I will be adding a +.020 billet rod for safe measure and increase in compression. Stock head. I wanted to add a small cam but I am not sure if there is any cam that is an “upgrade” that will be ok with the stock flywheel. Something that Is compatible with 10.8lb springs. (Considering the red or yellow stripe springs) The factory Coleman cam has the plastic gear. Also considering the 1.3:1 stamped rockers.
Any help is appreciated. Thanks.
Reply
