Closed Thread
Old 09-18-2019, 07:55 AM
Budget GoKart's Avatar
Budget GoKart Budget GoKart is offline
Aka a kenbar
Default Budget Ken bar aka budget go kart
Well i am technically named after my kart here on the forums. it was my first go kart of course never really had any major help on it exept fixing my wheel hub. Anyway its a ken bar dont know the exact model but i think its a pacesetter it was red originally. Someone painted it blue and did a wonderful job too! Then i got it and it was slightly rusty so i did a touch up with black paint. it used to have a 3.5hp briggs that ran great. Then i sold it and the guy destroyed the poor thing. Did a terrible black rattle can job, cut the frame to fit a 212 hemi, swapped the 41 sprocket for 35 broke, chunks off the manco cast aluminum wheels, busted the front wheel, broke the throttle mechanism, burnt out the brakes and broke the hub more. But he replaced the wheel bearings...
Sorry for the block of text.
Heres my plans
5Hp briggs and stratton (have):
Cam
Strip all the paint off of the engine and clear the bare metal
Port polish
Raptor 3 con rod
Bigger exhaust pipe
Frame:
Repaint dark metallic blue (color when i got it)
Unbend bent parts
Fix the cut in the frame
Some 5inch or 6 inch slicks all around
New wheel hub
New brakes
Replace just about every bolt
And add seat padding
Heres current pictures and old pictures
I gotta fix my flathead collection
The Following User Says Thank You to Budget GoKart For This Useful Post:
Old 09-18-2019, 08:39 AM
JTSpeedDemon's Avatar
2019 Build Off Winner!
Looks like a good plan!
Currently Flathead-Crazed
Old 09-18-2019, 09:12 AM
BigWes's Avatar
BigWes BigWes is offline
Good luck Budget! I love the Ken-Bar karts. I am glad you have chosen to bring it back to life.
This ain't rocket science boys!!!
Old 09-18-2019, 10:06 AM
Personally I like your original user title, "broke mechanic". Can't wait to see that thing flash down the street in a blue-and-lime-green streak! (pun intended)
Old 09-18-2019, 11:56 AM
Aka a kenbar
Bwahaha good one jt and thanks bigwes i forgot to add im probably putting some kind of body on it to protect the frame from my buddy isaac slamming into me like always.
---------- Post added at 11:56 AM ---------- Previous post was at 11:32 AM ----------
Quote:
also jt i am stripping all of the green paint off and making it either red or clear coating it
JTSpeedDemon (09-18-2019)
Old 09-18-2019, 02:57 PM
I'd keep it green.
That way it's tamper proof.
  #7
Old 09-18-2019, 05:28 PM
Dingocat's Avatar
Dingocat Dingocat is offline
Broke
Green = go. Good luck!
If it's not scary you're not going fast enough
The Following User Says Thank You to Dingocat For This Useful Post:
  #8
Old 09-18-2019, 06:33 PM
Tpdingo Tpdingo is offline
Quote:
I'm guessing thats why most briggs are painted red .
Give a wrench long enough and WD-40, and I can remove the world's rusty bolts.
  #9
Old 09-18-2019, 08:02 PM
Smerft85 Smerft85 is offline
Quote:
Actually I've only got 1 out of 7 briggs that are red! Most of mine are white.
As far as color on the kart the one we had as kids that looked just like yours came to us red, loved the kart, hated the color.
  #10
Old 09-18-2019, 08:03 PM
I like my orange one. Makes it look like a little small-block V8!
  #11
Old 09-18-2019, 09:09 PM
It might sound, and feel like one, but I think you might be missing a few cylinders . Add a radiator, fan, and stick a carburetor ontop of the plug with a nice "pietop" filter holder, and make it watercooled while ur going for the look.
The Following User Says Thank You to Tpdingo For This Useful Post:
Hellion (09-23-2019)
  #12
Old 09-18-2019, 10:21 PM
BigWes's Avatar
All the Briggs I ever seen were black and white except the custom jobs on racing karts...well, maybe I think I came across an occasional burnt orange one like JT has, but d@mn, it was an oldie...the last one I seen like that had a glass fuel bowl on it...those were good setups by the way. If you guys ever get a chance to experience one I highly recommend it. If the fuel bowl picked up trash you could visually see it. It had a drain cock on the bottom of it designed to drain out any water or trash prior to starting the engine or any time you needed to troubleshoot an engine issue. Some aircraft sill use a similar setup called a Gascolator I think. It works great. It allows for easy inspection and service. We can blame the politicians in California. If it wasn't for hackers and sneaky genius type computer-mechanics we actually wouldn't have any of the OBD2 code readers for home use. That wasn't in the original grand plan. Thank goodness for those guys! Anyway...
So does that thing run and drive at all Budget Spunkmeister?
That one rim looks busted real bad. I wish I had some spare parts to send you but I really don't have anything that small. Or actually in good shape.
  #13
Old 09-19-2019, 04:34 AM
Aka a kenbar
All the rims are busted just 3 of em hold air thats enough for me to go 40mph. And it hasnt caused and wrecks. And that last tire saved me from getting hit harder last time i got hit on the kart.
  #14
Old 09-19-2019, 06:16 AM
BigWes's Avatar
Quote:
Yea, 40 don't sound fast but it is plenty fast enough to get you dead. Bad wheels and tires are a risky habit to form. I'm not your parents so I won't try and sound like them.
Just don't do that with a car or motorcycle.
  #15
Old 09-19-2019, 07:39 AM
Aka a kenbar
It handles suprisingly well considering one doesnt hold air and ive had that experience with a mini bike already so i understand and yes the ken bar runs and drives fine.
  #16
Old 09-19-2019, 09:46 AM
And when the second tire blows out and you end up with concrete in your face don't tell us we didn't warn you. You should fix the tire.
  #17
Old 09-19-2019, 10:12 AM
Aka a kenbar
The other tire blew out before while i was going down the road and i stopped and drove it slowly home without steering
  #18
Old 09-19-2019, 11:40 AM
Dingocat's Avatar
Broke
When you see one wheel roll past you you might think otherwise. It went a good 40 feet into tall weeds before it stopped.
  #19
Old 09-19-2019, 11:42 AM
Yeah, go buy some new tires.
Tip - Go mow some lawns. Mowing season is almost over, but just today I still made $50 mowing one lawn. That's enough for about 3 tire tubes.
  #20
Old 09-21-2019, 08:37 PM
Diy motorsport Diy motorsport is offline
What’s your wheel base center to center?
Closed Thread
