Go Back   DIY Go Kart Forum > Building Plans And Advice > Electric Projects
Reply
  #21
Old 10-20-2019, 03:29 PM
mckutzy mckutzy is offline
I decided I could do without the through hole Gland, through the mirror mount... It would be cleaner... but I cant really find anything right now...Ill wait I guess...
In the mean time... I found an easier rout, that is, through the fender gap of the door...
No holes to drill... It seals by the door gasket, and routs inside nicely...
Im still working out the side vents in the defrost, but the top works like it should. So for now Ill leave out the vent deflectors and leave it as is...
I Soldered the connections( give a lower profile for shrink) and then shrinked individually and over the joint as a whole....I then found some long length shrink tube, and sleeved/Shrinked it over the joint to seal the outside, and along the length leaving a few inches for the power-in connections. I didnt have much for any other sleeving material... so that will do for now... Should be water resistant for a good while...
Powered up and it worked... Looks good too.... Have to wait for a darker time and Ill test in the darker road or wait till I go to work in the morning.... Either way.. Im happier...
  #22
Old 10-20-2019, 07:56 PM
itsid's Avatar
itsid itsid is offline
exposed wires are prone to be cut by idiots,
uv-rot by sunlight,
or internally rust by rain and frost (do not underestimate capillary effects)
Sooo.. for a brief period of time, sure..
for a permanent solution, I'd vote for "Nope!"
  #23
Old 10-20-2019, 10:22 PM
Fair enough....
  #24
Old 10-21-2019, 06:56 AM
itsid's Avatar
But that had me thinking..
is there enough wire to take the long 'manufacturer' route?
that is
mirror into the door, down the inside to just below the upper hinge, through the tunnel, into the chassis and up to the dash board again?
  #25
Old 10-21-2019, 08:19 AM
It isnt an electric adjustable mirror. So the outer bucket just contains the mirror support, the bracket mount is solid, an no way into the door/cab...
I did think of that aswell... hide the wire along the edge of the mirror and into inside... but thats when it came down to drilling into the mirror mount as there is a clean passthrough into the cab.
  #26
Old 10-21-2019, 09:34 AM
Functional Artist's Avatar
Functional Artist Functional Artist is offline
IIRC that type of mirror is connected to the door with (3) bolts (from the inside)
& the door itself should have a hole for the wires for power/heated mirrors (even if not equipped with that feature/option)
I think what Sid is suggestin' is to drill a small hole (just big enough for the wire) into/thru the (triangular shaped) mirror mounting/housing
...then, run the wire thru/inside of the door etc.
Which would make for a safe'er, more protected & a cleaner look
Short, sweet & to the point
RESISTANCE IS FUTILE
  #27
Old 10-21-2019, 10:47 AM
itsid's Avatar
yeah essentially.. a small hole for the wire to get into the plastic mirror housing
I thougt it had a lever to adjust the mirror from the inside..
so there's still a passthrough there ..
and tbh I was expecting electric windows (so there'd be a tunnel to the door)
at least there should be plastic caps where the tunnel would be between door and chassis..
*shrugs*
  #28
Old 10-21-2019, 11:52 AM
The tunnel exists in the door frame... Behind the mirror mount...and a trim cap inside..
The pathfinder d22 typically has adjustable from inside mirrors, electric or lever steer... The same doors of the same family...
Reply
