Reply
Old 03-31-2019, 10:14 PM
joehornet65 joehornet65 is offline
Junior Member
Default starting a new arachnid build
Hi all, im starting my first gocart build and I've chosen the arachnid. I see theres a lot of spidercart builds on the site already. Im currently at the stage of pile of steel. I've got to get a metal chopsaw and then ill be off to the races! any direct pointers would be appreciated! one thing I was wondering is about the front suspension. ive read that it needs to be widening from the plans. should i wait to get a rack and pinion and measure off that? Thanks!
Old 04-01-2019, 12:51 AM
landuse's Avatar
landuse landuse is offline
Welcome! I would read through all the arachnid builds on the site, especially the one that silvergrizz did
http://www.diygokarts.com/vb/showthread.php?t=8493
http://www.diygokarts.com/vb/showthread.php?t=29167
http://www.diygokarts.com/vb/showthread.php?t=8537
Old 04-10-2019, 09:16 PM
Junior Member
Default progress
i chopped up some tubing and welded up the bottom frame. it was a pretty fun event. i made a jig out of a piece of 3/4 plywood with 2x4's under it. it came out about a 1/16" off corner to corner but overall im happy with it. im using an eastwood 200 tig welder for it since thats all i have available. i used a piece of 1x6 and marked off all the angles i needed then used an angle transfer do-dad to get the angle right on the chopsaw. that worked out great! I welded up the outer frame then put in the inner pieces. i only had to cut the inners down an 1/8" to get them in there.
Old 04-11-2019, 01:48 AM
landuse's Avatar
Nice start!!! It looks like you will be fine doing this build
Old 04-11-2019, 12:49 PM
JTSpeedDemon's Avatar
Currently flathead-crazed
Nice TIG welds!
Normally, I hear of MIG welders to make frames, but those are BEAUTIFUL beads!
Keep up the good work!
"(Speed Demon)Speedin' on the freeway, gotta get a leadway..." -Michael Jackson
Old 04-15-2019, 07:43 PM
Junior Member
I would rather mig it, but my brother in law just happened to have a tig welder he wasn't using so i grabbed it. ive been real impressed with it so far, except when i tried using 75/25 gas.
  #7
Old 10-05-2019, 10:26 AM
0071241 0071241 is offline
Junior Member
Hi! I was wondering if and how you had gotten the Arachnid plans, if someone you knew had them or if you bought them off spidercarts website.
Thanks!
Reply
