Go Back   DIY Go Kart Forum > Building Plans And Advice > Electric Projects
Reply
  #101
Old 03-23-2019, 10:55 PM
Functional Artist's Avatar
Functional Artist Functional Artist is offline
That should be your voltage lead
...it connects to (B+) on a volt meter
(about the same as connecting straight to the positive (+) terminal of the battery pack)
See this thread for more info
http://www.diygokarts.com/vb/showthread.php?t=38583
RESISTANCE IS FUTILE
The Following User Says Thank You to Functional Artist For This Useful Post:
sikbrik (03-23-2019)
  #102
Old 03-23-2019, 11:03 PM
sikbrik sikbrik is offline
http://youtu.be/uUmI1F-xrqs
Thanks for that link, functionalartist, that's really helpful!!
The Following User Says Thank You to sikbrik For This Useful Post:
Quinc (03-25-2019)
  #103
Old 05-15-2019, 02:58 PM
Bmr4Karts Bmr4Karts is offline
Can this system get 350lbs of kart and driver up to 25mph while still having enough torque for 20 degree slopes?
  #104
Old 05-20-2019, 11:30 AM
I think it'll be tough. We're moving about 200lbs of kart + driver at about that pace on slopes. It hits 35mph on flat pavement. If we geared down to a 25mph top speed, it'd likely haul another 150lbs around pretty well and handle 20 slopes. He can crawl a 35 hill with decent pep but the motor gets hot.
Bmr4Karts (05-20-2019)
  #105
Old 06-18-2019, 04:17 AM
Can a sinusoidal brushless controller be used with these motors?
  #106
Old 09-09-2019, 11:41 AM
So what's the actual difference between the 48v and 60v motors? I've put 70v through my 48v motor without any issues. Also, the 48v motor with a shunt modded 48v controller pulls 50 amps and moves my 300lbs of me and kart up hills with ease.
  #107
Old 09-10-2019, 06:51 AM
Quote:
Originally Posted by Bmr4Karts View Post
So what's the actual difference between the 48v and 60v motors? I've put 70v through my 48v motor without any issues. Also, the 48v motor with a shunt modded 48v controller pulls 50 amps and moves my 300lbs or me and kart up hills with ease.
Effeciency
I put ~40V thru a 24V 450W motor
http://www.diygokarts.com/vb/showthread.php?t=36894
I also did some testing "straight" off of the battery pack
http://www.diygokarts.com/vb/showthread.php?t=39287
* "Personal Analysis, of the (3) tests with the ZY1020 48V 1,000W motor
Alfa Wheels speed controller
Take-off ~25A
Accelerating ~25A
Constant/crusin' ~12A
Top speed ~14 MPH
TD Pro speed controller
Take-off ~30A
Accelerating ~30A
Constant/crisin ~10A
Top speed ~14 MPH
With-out a speed controller (just a battery pack, beefy switch & motor)
Take-off (up to) ~100A
Accelerating ~50A
Constant/crusin ~10A - 12A
Top speed ~14 MPH
So, (as Sid said) the speed controller (available amps) doesn't seem to be holding the motor back
The only advantage, I see, is a "harder" acceleration
...but, at the expense of "lots" of amps
…& the top speed was still ~14MPH either way"
  #108
Old 09-10-2019, 02:51 PM
Hey FA, thanks for the response, but I'm looking for the difference between the 48v and 60v motors. I think the 60v is less rpm per volt which means it should have more torque per rpm. I know I'm running th 48v motor at over 7000rpm at 70v and think the 60v motor won't be spinning as fast with the same volts. Better for long term durability.
Reply
