Go Back   DIY Go Kart Forum > Build Contest > Build Off Contest Build Logs
Reply
  #21
Old 03-17-2018, 01:01 AM
Joe-405's Avatar
Joe-405 Joe-405 is offline
2018 Buildoff Winner ! 😎😎
Got the new floor fully welded and also got the new tubes in for the 3 pedal setup instead of the standard 2 setup. And I have more clearance now that my seat mounts are lower which means more sleeker roll cage design I hope. And itís a roller again also. Iím kinda stuck now without a engine. Most of the welding is done minus the rear section it looks like and some little stuff.
Took my grinding wheel and cut slots in the sheet metal to weld it back in the center pieces. Only reasonable and easy thing I could think of. Worked out great also.
5F61941E-4EB3-4898-965D-C68002D5722C.jpeg   40BE1606-8E05-46A8-9B38-CB41893B08F8.jpeg
351B012E-461A-43B9-986C-6FCC77FF0CF0.jpeg   DA843BBB-6911-4344-BC2E-EF7E5C7FD84F.jpeg
The Following 4 Users Say Thank You to Joe-405 For This Useful Post:
bob58o (03-18-2018), ezcome-ezgo (03-19-2018), Kartorbust (03-20-2018), landuse (03-22-2018)
  #22
Old 03-18-2018, 08:42 PM
Joe-405's Avatar
Well I opted for the cheaper engine I’ve told you about prior. It’s a 600cc Kawasaki zx6r. Will pick it up tomorrow. It was only $300 so I’m not complaining. I can always buy a bigger one later or just add a lot of boost to this one. Hahaha.
  #23
Old 03-18-2018, 08:49 PM
anickode's Avatar
anickode anickode is offline
Quote:
That's called plug welding, and it's perfectly acceptable and widely used for attaching sheet metal to structural elements in the middle of a sheet.
The Following 2 Users Say Thank You to anickode For This Useful Post:
Joe-405 (03-19-2018), Kartorbust (03-20-2018)
  #24
Old 03-19-2018, 10:05 PM
Joe-405's Avatar
Well I picked up my ď600Ē today. Hahaha.
Remember no replacement for displacement so we can double my cc numbers now. And it has work with aftermarket cams so it should make 200hp easy on motor alone with no power added. Now who has a turbo laying around ?
And got a piranha from desert karts for something later on. And a trike to work on for a guy at work.
7DE1C925-9DC9-44E9-BE5F-DEF8B1587CD7.jpeg   D1C9BBD5-6061-4C5A-B53C-28AF80EAE469.jpeg
28443CF9-DA17-40FD-8EE7-9247D36D8B92.jpeg   A241C0CA-A2C4-41C2-B7D6-687193287523.jpeg
  #25
Old 03-20-2018, 07:35 AM
ezcome-ezgo's Avatar
There is something magical in the 405.
The Following User Says Thank You to ezcome-ezgo For This Useful Post:
Joe-405 (03-27-2018)
  #26
Old 03-20-2018, 01:43 PM
Joe-405's Avatar
Quote:
Yeah progress of the worlds fastest Yerf dog. Lol
  #27
Old 03-20-2018, 02:51 PM
TT540 TT540 is offline
Newb
****. Needs moar drag radial! I wonder if the rear swing arm pivot point needs something more than some tabs with a bolt through it. Something to distribute that load more.
I was going to suggest drain holes in the floor pan. But something tells me this thing will not see much the elements.
  #28
Old 03-20-2018, 08:09 PM
Joe-405's Avatar
Gonna change the rear shocks later. This is just to roll it around with.
Got the swingarm fully welded and itís rolling. The engine is sitting there as I gotta order some welding tabs and the front engine mount.
8E27ADAF-130F-44F3-8DEB-645259FFA0CC.jpeg   6E863389-B5A1-4BBB-828B-5F93B8631591.jpeg
378BB5A5-247D-4A37-A9B6-6B36E97A7260.jpeg   1EB3D327-95D7-4777-9C0F-8E0C2AB49254.jpeg
D14389FD-F29E-4E08-B98B-6842CF635000.jpeg   02F9EEFD-1AD3-4AD5-A07B-1A8387B11A22.jpeg
0D409637-E5D7-4927-BB30-6185F8CF338C.jpeg   5C263266-7794-429D-9FE0-346D5EC1B783.jpeg
The Following User Says Thank You to Joe-405 For This Useful Post:
ezcome-ezgo (03-21-2018)
  #29
Old 03-21-2018, 12:05 AM
Joe-405's Avatar
Almost in for good...........
4D6345C1-32E8-4E27-A68D-A95E19F27759.jpeg   138B4955-324F-42BD-8BBB-EA2938D2C3DA.jpeg
bob58o (03-21-2018)
  #30
Old 03-21-2018, 07:03 AM
Epic.
  #31
Old 03-21-2018, 06:30 PM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
What kind of ratios with that transmission?
I have no idea what the power band might look like and am curious to the gearing you will use.
  #32
Old 03-21-2018, 11:10 PM
Joe-405's Avatar
Be sitting down when you figure this up. But Iím running a 16 tooth front with a 36 tooth rear and my tires have a circumference of 66Ē. Equals to about 178mph at redline in 6th. Which believe it or not is slower than stock gearing !
bob58o (03-27-2018)
  #33
Old 03-22-2018, 12:54 AM
landuse's Avatar
landuse landuse is online now
You have made some awesome progress!! Is it just me or the camera angle, but are those shock tabs not a little flimsy looking?
Also.....I was wondering...why did you extend the rear so far out when the engine only takes up about the first half of the swingarm? Is that for the sprockets etc?
The Following User Says Thank You to landuse For This Useful Post:
Joe-405 (03-24-2018)
  #34
Old 03-22-2018, 10:46 AM
Newb
dynamic balance those tires! This thing is going to be a hoot. It's very buggy like.
The Following User Says Thank You to TT540 For This Useful Post:
Joe-405 (03-22-2018)
  #35
Old 03-24-2018, 03:19 AM
Joe-405's Avatar
I am gonna make a bar around the engine for better shock placement when I get the new top of the cage welded on. The rear shocks are temporary to roll it around with.
And the rear was extended longer than I needed it to be. I planned on moving the rear axle up and using the excess for a rear bumper of some sort. But after looking at it, I canít move it too much or else the sprocket and chain wonít have the clearance it needs. Iím also placing the fuel tank over the axle so it wonít look as long when Iím done. Iím also debating building a wing for the back also to offset the looks.
landuse (03-27-2018)
  #36
Old 03-26-2018, 08:06 AM
Better put a wing on the front too, to keep it on the ground whilst accelerating.
  #37
Old 03-27-2018, 06:20 PM
Joe-405's Avatar
Well I got to go get a foot of flat plate and tubing to finish the front mount. But the rear tabs are tacked and in spot finally. And I got the new floor sprayed with bed coating to protect it and keep my feet from not sliding around a lot. These rear tires are 22x10x10 and sure are looking inadequate every time I see them. Might have to go bigger me thinks.
B44B64DC-2242-4315-A702-828E02DE6665.jpeg   B637C9AA-2D65-4744-9CEB-16269A372966.jpeg
4FC52BEE-20A1-486D-81CB-BA8E99407725.jpeg   0EB9C9B0-E4CE-4DC6-BBE6-5EE2C2BE0BA5.jpeg
The Following 3 Users Say Thank You to Joe-405 For This Useful Post:
bob58o (03-27-2018), ezcome-ezgo (03-28-2018), landuse (03-28-2018)
  #38
Old 03-28-2018, 10:51 PM
Joe-405's Avatar
Well got the mounting plate welded up. And retapped the outside bolt holes to mount it too. The guy before me broke the bolt then turned around and broke a drill bit off in the left middle hole. So I got 3 bolts holding it now which is actually stronger than before and it spreads the weight more evenly also. Got all the tabs tacked in and ran out of welding wire. Go figure !
A5CD38C7-8211-4B3A-9617-CA40C4EF451B.jpeg   925EC170-A1E1-4E09-AD2A-7B140195EB07.jpeg
2D262334-A2B4-42D8-98FF-204F4D28D0FA.jpeg   3BE7A6A6-9541-4105-9089-494A0EB69898.jpeg
  #39
Old 03-28-2018, 11:40 PM
andrecht's Avatar
andrecht andrecht is offline
Jup, picture = me
Thats plenty strong 👍
Sent from my SM-G570F using Tapatalk
The Following User Says Thank You to andrecht For This Useful Post:
Joe-405 (03-29-2018)
  #40
Old 03-29-2018, 07:13 AM
That hole got boogered up!
Reply
