Go Back   DIY Go Kart Forum > Build Contest > Build Off Contest Build Logs
Closed Thread
Old 11-01-2017, 11:04 PM
jerseydevil jerseydevil is offline
Default 2017 - build comp entry crossfire mbx racer
HOWDY!
brandy new so i might need help. i read the rules just not sure about the pic w/ the sign thing, but we'll see if i can figure it out.
i am actually a Trailmaster, SSR, BMS, DRR USA dealer and have been a buggy enthusiast for the last 8 years. i opened the shop about 3 years ago but my heart is in building more than selling.
i have quite a few builds under my belt and started this one 2 weeks ago ( the 2nd week of OCT).
i stumbled on this forum and saw the build off competition and figured what the heck. i have been working on starting some sort of buggy racing events here in Fla and our next event is Dec 31st so this one will need to be done before then. anyone interested......https://www.facebook.com/profile.php...9726&ref=br_rs
anyway on w/ the build
started out as a tomberlin crossfire 150 with a broken swingarm and no engine. so after i stripped it down it looked like this.
still not sure about the cookies sign, might need a little help.
The Following User Says Thank You to jerseydevil For This Useful Post:
ezcome-ezgo (11-02-2017)
Old 11-01-2017, 11:14 PM
so this is actually being built for my wife to race and she is a fan of crossfires. her 1st one i swapped a 250 in it and then chopped it in 1/2 along with a hammerhead 250 and built what i call the "crosshammer".
here are some before and after pics. the pics of it yellow was after the 250 engine swap and the green pics are the "CROSSHAMMER" pics.
1526909_574094462669700_4057660_n.jpg   10011257_613517372060742_1863533943478475050_n.jpg
10259878_613517432060736_3813864082078751766_n.jpg   10150735_611905752221904_7230755496567137412_n.jpg
Old 11-01-2017, 11:23 PM
so the goal is to be a light , single seat racer, the swingarm had a broken leg that had been ridden by the previous owner so it was completely tweaked. i opted to cut it all off and start from scratch.
22279671_1455470967865374_5172769249903685892_n.jpg   22366527_1455470974532040_5873862278419216079_n.jpg
22310504_1455470997865371_662915239624578481_n.jpg   22405814_1455471061198698_3840987510958241632_n.jpg
22281740_1455471124532025_1300332766101767997_n.jpg   22406104_1458799594199178_6817299636214652148_n.jpg
22406184_1458799600865844_1973303214074734725_n.jpg   22406394_1459589284120209_5956610533966560081_n.jpg
22406544_1459589374120200_1535937054933777987_n.jpg   22489921_1459589370786867_3625833840190049325_n.jpg
Old 11-03-2017, 01:34 AM
OzFab's Avatar
OzFab OzFab is offline
Quote:
Have a look at some of the other entries; they all have a sign (a piece of paper, cardboard, sheetmetal, whatever) with the following written/painted/printed on it: "DIYGK 2017 - Cookies!" & the date the pic was taken...
Old 11-03-2017, 07:01 AM
landuse's Avatar
landuse landuse is offline
Quote:
Yip!! All you need is the sign, and your build will then get moved to the build off area for the contest
Old 11-03-2017, 09:02 PM
thank you gents, i'll get on it.............i'm a dope!
  #7
Old 11-04-2017, 12:08 AM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
Quote:
Unless you are KF, then you just stay here.
  #8
Old 11-04-2017, 09:15 PM
okeedoke....... not very high tech, but let me know if this works
  #9
Old 11-04-2017, 11:02 PM
Functional Artist's Avatar
Functional Artist Functional Artist is offline
Nope!
try again
be more creative
JK
welcome
  #10
Old 11-05-2017, 12:20 AM
2SlickNick's Avatar
2SlickNick 2SlickNick is offline
American Minibikes @ FB
Look forward to your build...I used to be on buggy masters all the time and seeing all of your projects.
Good luck.
https://www.youtube.com/user/dirtyinaz
  #11
Old 11-05-2017, 07:17 AM
Quote:
Good luck.
hahahaha, did you quit BM? now that you mention it i dont see you there much but i'm just usually too busy to troll long.....just post and run.
aint we friends on FB too?
  #12
Old 11-05-2017, 07:51 AM
well then i will carry on and try to get the 3 weeks of progress on here.
took the crossfire chassis and carved it down width wise to a single seater. then welded in some new tubing to tie it back together.
i chopped the cage down 2" and put an extra bend in the A-pillars to make up for it. i cut the main hoops and bent a new over the head hoop and tied that in so the cage ends behind the seat.
cut some panels out of aluminum and ran flat stock around the sides of the cage to mount them to.
22366776_1455481297864341_1767687657515796987_n.jpg   22490061_1460475977364873_6070455386795080792_n.jpg
22406335_1460476044031533_7026384411929765313_n.jpg   22528218_1462173580528446_1632795119824885696_n.jpg
22528453_1462173670528437_2031728577072547611_n.jpg   22490135_1462173577195113_8167994690241340211_n.jpg
22491921_1463039913775146_6593584156627205577_n.jpg   22549533_1463039920441812_7793264509803058535_n.jpg
ezcome-ezgo (11-06-2017)
  #13
Old 11-05-2017, 11:18 AM
the next idea i had was to put a roof on it, just never something ive tried before. i didnt want it to be just a flat pan on top so i welded in the front crossbar to it with a bend to try and use the cage as a template to introduce some curves to it. i cut what i thought was a close cardboard template and used it to get the basic shape. cut the aluminum out to see how far off it would be. when i got close i welded in tabs to bolt it down then clamped the roof on and drilled the bolt holes. from back to front clamped and drilled one at a time. whatever bit of overhang was left i ground down to match the cage.
22554792_1465607106851760_7896573703871174753_n.jpg   22688916_1465607573518380_2280677113165887983_n.jpg
  #14
Old 11-05-2017, 11:34 AM
the next thing was to center the tank mount in the rear and figure out what i wanted to do behind the seat. i didnt want any more bars , i just though the look would get cluttered and just add wait. and so far this build has turned out a little different than my previous builds look wise.
i used to do a lot of song writing and home recording and i would challenge myself to make sure that each song sounded different than the next, it had to be good and somewhat self pleasing but it could sound like the previous ones. i have already had people tell me between Lucifer, my black Joyner in the trailer pic, and the Crosshammer that my cages had a style, that they looked like "my cage". even though they are different , they "looked like the same guy built them"....well, a style is cool but i wanted to challenge myself to do something different that I hadnt done before so not to fall back on a default way of doing things.
so i decided to go w/ a deck that the tank would set into and a winged look. unfortunatelt my TSC brake started stressing out trying to bend the sheet of alum for the deck so i went flat and used aluminum angle i had in the shop.
The Following 2 Users Say Thank You to jerseydevil For This Useful Post:
6.5hp (11-06-2017), ezcome-ezgo (11-06-2017)
  #15
Old 11-05-2017, 11:37 AM
  #16
Old 11-05-2017, 11:41 AM
in the meantime my father in law , who like to paint and do body work sanded down the swingarm and primed and painted it
  #17
Old 11-05-2017, 11:46 AM
last friday got the motor rebuilt, bumped it up to a nakamura 155cc kit and charmo racing head. just need to slap the clutching into it. i also fabricated the new exhaust pipe this weekend. this should bring me up to date. today i work on relocating the pedals.
  #18
Old 11-05-2017, 06:50 PM
OzFab's Avatar
That'll do it, welcome to the build-off
  #19
Old 11-05-2017, 08:22 PM
2SlickNick's Avatar
I go on there every now and then, but I sold my buggy, and I have been building karts and minibikes Mostly mini bikes Lol) lately. Yes we are friends on Facebook to have seen the buggy races which are really cool.
  #20
Old 11-05-2017, 09:03 PM
stay tuned more are coming.
Closed Thread
