Go Back   DIY Go Kart Forum > Build Contest > Build Off Contest Build Logs
Closed Thread
  #41
Old 09-21-2017, 07:33 AM
ezcome-ezgo's Avatar
That's beefy. Nice work. Also potatoes.
  #42
Old 09-22-2017, 07:09 AM
Slackjumper's Avatar
Slackjumper Slackjumper is offline
Angle Grinder Surgeon
Default Tested it out last night.
I drove it around with the new 40 series and it is definatly more powerful and faster than with the stock 30 series. It won't chirp on concrete, but to get the 30 series to launch like that I had to change out the drive springs to let the belt slip, which burnt it up quick. I weigh about 185 and this kart will do donuts on gravel for me no prob. The belt gets only slightly warm when pushing it hard to the point where the 30 series belt burnt. I'll have to get out the GPS soon to get a top speed but it seems around 35-40mph. So far I'm quite happy with the performance of the 8HP with the comet 40. I still have 3 upgrades to do now: aluminum sandwich sprocket guard, steering stops, paint the jackshaft bracket.
Quote:
Originally Posted by Bubba_Z View Post
Sorry I just dont agree that a 40 can run the driven "outboard" like you are forced to with a plate.
Agreed. I considered this for a while after watching a GoPowerSports 40 series upgrade kit video, but I think the belt would wear out a lot faster running at a skew during high speeds. Maybe if one had a long motor shaft they could also flip the drive pulley, but I don't.
---------- Post added at 05:09 AM ---------- Previous post was at 05:03 AM ----------
Quote:
Thanks man. Sorry, not many potatoes up in Sandpoint. That ruckus is all down south.
  #43
Old 09-22-2017, 11:25 PM
Default Jackshaft bracket painted
Here is the jackshaft mount all painted up with engine enamel.
The Following User Says Thank You to Slackjumper For This Useful Post:
Randy H (09-23-2017)
  #44
Old 09-24-2017, 03:54 PM
Default Steering stop
I welded flange nuts to the top of the steering spindles and now I can thread a bolt and jam nut for limiting the steering. This is necessary for the larger polaris scramble tires. The final hub spacers on the spindle ended up at 1.25 inches. These spacers and stop nuts keep the tires from rubbing the roll bar frame. The spacers also put the front tire width at the same as the new larger rear tires, which are on the new 4-on-4 flange hubs.
  #45
Old 09-24-2017, 06:18 PM
Kansaskart Kansaskart is offline
Nice. Like the 8hp briggs used to run them a lot 35 years ago.
  #46
Old 09-24-2017, 09:05 PM
Quote:
Thanks! I think it turned out great for my first thing like this. Wow 35 years is quite a long time ago.
  #47
Old 09-26-2017, 09:36 PM
Default Quick video
Me and my 2yr old peeling out a donut:
https://youtu.be/9d0m5V0JTpw
Top speed is 35mph with the governor still connected.
bob58o (11-30-2017)
  #48
Old 11-29-2017, 01:57 AM
Default Port, polish and brows
I had a few hours to port, polish and shave the brows on the head of the 300cc 8hp flathead briggs.
ezcome-ezgo (11-29-2017)
  #49
Old 11-29-2017, 02:03 AM
Default Ports
Dremel with flex shaft and end-mill works well. Finish with grind cone bit, then sand. Then put valves back in.
  #50
Old 12-24-2017, 10:46 PM
Tire chains!! Woo hoo! https://youtu.be/seMN1mhr6hg
  #51
Old 12-25-2017, 06:01 PM
Kartorbust's Avatar
Kartorbust Kartorbust is offline
Those from a garden tractor?
Sent from my SAMSUNG-SM-G935A using Tapatalk
  #52
Old 01-01-2018, 07:11 AM
Default Tire chains for manco dingo
The chains are for a car: $40 cheapos from Walmart cut to length. They work well and fit snug between the knobs if the tire knobs are worn down a bit. Otherwise I would try to skew them to route them over top the knobs.
Kartorbust (01-01-2018)
  #53
Old 04-12-2018, 01:33 PM
Dingocat's Avatar
Dingocat Dingocat is offline
Broke
I got a dingo down in NC, sadly we didn't have a way of transporting it so it will hang there untill relitives come up to OH in the fall, It will be a prodject as it's been sitting outside for years with seized steering and what looks to be a bent axel
  #54
Old 04-15-2018, 01:08 PM
Quote:
Sweet. Doesnt sound too bad since axles are all over the internet. Also you might check out surpluscenter for a great deal ($299) on the 10hp vanguard 305cc. 19L232-0111-F1. It fits the 8hp dingo well and the 5hp if you move the gas tank and fab a new jackshaft.
Sent from my LG-H932 using Tapatalk
  #55
Old 04-15-2018, 08:03 PM
BeaterofAincrad BeaterofAincrad is offline
2018 Build-Off Contestant
Whered u get that seat? It looks nice! its prolly out of my price range though
  #56
Old 04-16-2018, 09:08 AM
JEGS. ~$30 + $30S&H
BeaterofAincrad (04-16-2018)
  #57
Old 04-16-2018, 02:43 PM
Quote:
Originally Posted by Slackjumper View Post
JEGS. ~$30 + $30S&H
Thx, unfortunately it looks like Ill stick with my used grouting sponge & ductape seatXD
  #58
Old 04-23-2018, 07:43 AM
Dingocat's Avatar
Broke
Thx for the Idea, I'm a broke teen without a job though as with it I would need a new TC, so until I get a job I'm probably just going get a predator 212 so the 5 hp on it can go to my other go kart
  #59
Old 05-22-2018, 01:37 AM
Finally got a seatbelt installed.
---------- Post added at 10:37 PM ---------- Previous post was at 10:32 PM ----------
Got the 10hp 305cc Vanguard OHV installed. Dropped from a 54T to a 48T for the axle sprocket and it seems pretty good me. Still peels out easier than the 8hp flathead and has a faster top end.
ezcome-ezgo (05-22-2018)
  #60
Old 05-28-2018, 09:44 PM
Dingocat's Avatar
Broke
Been meaning to ask, what size back tires are you running?
Closed Thread
