  #21
Old 04-30-2016, 02:24 PM
ChromeRhino's Avatar
ChromeRhino ChromeRhino is offline
Originally Posted by chancer View Post
Any better ideas out there?
Craigs list.... For a different set of used wheels.
Or ask around here? USPS Shipping is cheap.
I have been looking on craigslist.. nothing has popped up that would fit this application yet but I will keep trying. Maybe I will try on here too. Thanks.
  #22
Old 05-07-2016, 12:01 AM
I got the motors, electronics, jackshafts, chargers and axle gears in the mail this week! Thanks again, Chancer I opened it up like it was Christmas morning and sorted it all out. Now to plan out placement and how to get it all to fit, workung and look good.
I was going to do a little suspension in back also but that would mean I would thave to triangulate the rear axle, mount the motor and jackshaft to move with the rear axle, and do it in a way that it can't be seen but yet doesn't disrupt what little ground clearance it has. Its pretty long and the ground clearance won't be but several inches so any bump or grade transition will bottom it out if I lower the clearance much more.
We might actually be able to get something accomplished on this thing tomorrow!
  #23
Old 05-07-2016, 12:24 AM
chancer's Avatar
chancer chancer is offline
ɔ ɥ ɐ u ɔ ǝ ɹ
Cool Glad you got everything ok. I forgot you were a Long haul Driver so I was expecting to hear earlier this week.
I noticed 1 of the motors has a spot where the wires got hot. That is from Running the batteries down too low. But everything was working before disassembly.
Why don't you, go back to your double wide and fry something!
  #24
Old 05-07-2016, 06:42 PM
Kelly Wood's Avatar
Kelly Wood Kelly Wood is offline
The Mad Kartist
Originally Posted by ChromeRhino View Post
Yeah... but at this rate I might as well add designs for treads so she can ride it in the snow, when I finally finish it! Lol
Hopefully I can get an hour or so to work on the projects in the next couple of days.
I'm trying to decide on a drive axle. I am going to use those bumb 6 hole split rim jobs but I don't kni w the best... well, cheapest, way to attach them to the axle. I was thinking weld a custom flat piece of stock on and drill 6 holes for bolts. Center everytging up, put the bolts thru and tack weld them to stay in place.
I was looking at those strange rims. How many of them do you have? And what's the dia of the bolt pattern? I might have something.
Kelly "Mad Kartist" Wood - http://www.diygokarts.com/vb/album.php?u=9686
  #25
Old 05-07-2016, 08:10 PM
I'm not quite sure. I will go check when I get home. Took the boy to the skate/bike park for some scars... I mean... some fun
---------- Post added at 09:10 PM ---------- Previous post was at 09:00 PM ----------
2 3/4" best I can tell
  #26
Old 05-08-2016, 01:54 PM
2 3/4" center to center
  #27
Old 05-08-2016, 01:57 PM
Poboy kartman Poboy kartman is offline
Banned
Southern or Northern measurement?
  #28
Old 05-08-2016, 06:13 PM
Lol Northern. I'm not fully fluent in Southern measurements.
  #29
Old 05-08-2016, 07:50 PM
Flyinhillbilly's Avatar
The great cornholio
Wallered out is the most commonly used southern measurement around here.
  #30
Old 05-08-2016, 08:00 PM
chancer's Avatar
ɔ ɥ ɐ u ɔ ǝ ɹ
"It's Wallered out just a schosh"
Wallered out: To make a hole bigger by reaming it to the extreme.
Schosh: is a hair less tham a smidgen.
Smidgen: Cookery term for a small amount.
Don't Worry Ron we will get you up to date.
  #31
Old 05-08-2016, 08:03 PM
Banned
But you can't trust Northern measurements. You never know if they're "Dead nuts" or a female pubic hair off!
  #32
Old 05-08-2016, 08:06 PM
chancer's Avatar
ɔ ɥ ɐ u ɔ ǝ ɹ
My old man used to say "a little RED pubic hair"
Later in life I checked, they are the same!!!
  #33
Old 05-08-2016, 08:11 PM
Banned
Wait....what? IDK...IDK!!!! Do I divide by 8? So....80 mph...IDK!...IDK!!!
Metric is soooooo much easier....you always divide by 10....
Now I've done it!!!! I'll be up all night trying to convert pubic hairs to metric!
  #34
Old 05-08-2016, 09:31 PM
chancer's Avatar
ɔ ɥ ɐ u ɔ ǝ ɹ
I said they are the SAME!
No need to convert.
  #35
Old 05-08-2016, 09:58 PM
Banned
No need to convert.
Thanks sooooi much fella! Those operations are expensive. I always figured it didn't make much difference to you boyfriend!! LOVE and kisses...see ya soon!
  #36
Old 07-24-2016, 10:40 AM
Hey everyone. I'm still around. I got caught up with other atuff. Working on getting my boat and popup camper that I bought for $200 usable. Been working and trying to keep my head above water. Money seems to be elusive and disappears just before I get a chance to buy stuff for the build projects that would need to continue the builds.
The Following User Says Thank You to ChromeRhino For This Useful Post:
Jrgunn5150 (07-25-2016)
  #37
Old 07-25-2016, 01:37 PM
Jrgunn5150's Avatar
Jrgunn5150 Jrgunn5150 is offline
Rudderless
Glad to see you're still around bud. Try and do one thing a day, and you'll get there.
I need an adult.
  #38
Old 07-25-2016, 04:43 PM
The great cornholio
Story of my life right there, between remodeling my house, putting my race car back together, and fighting with my turbo truck I have pretty much zero time for projects. I'm almost caught up now though and it'll be ON then.
