Old 09-14-2013, 07:11 AM
Doc Sprocket's Avatar
Default Online Service Manual Resource
Folks, an acquaintance of mine posted this on another forum. He sourced it from yet another forum (LOL) and I'm copying it here for everyone's benefit. I have always said that a manual is the most valuable tool in the toolbox, so here's some great tools for you. Included is the originating link.
Briggs And Stratton Single Cylinder Engines
Single Cylinder OHV Repair Manual- https://docs.google.com/file/d/0B6Na...o3azl6OUU/edit
Single Cylinder L-Head Repair Manual- https://docs.google.com/file/d/0B6Na...s3Z2Q2X00/edit
Gas & Electric Outboard Repair Manual- https://docs.google.com/file/d/0B6Na...dNLWNCUk0/edit
DOV 700-750 Series Repair Manual- https://docs.google.com/file/d/0B6Na...NZNXVCVDg/edit
Briggs & Stratton Micro Force Engine Service Manual- https://docs.google.com/file/d/0B6Na...ROeUktYzA/edit
Common Specifications For Briggs & Stratton Single Cyl OHV Models Except Intek- https://docs.google.com/file/d/0B6Na...JjTUZUMVk/edit
Common Specifications For Briggs & Stratton Single Cyl L-Head Models- https://docs.google.com/file/d/0B6Na...pBNDdrTUE/edit
Common Specifications For Briggs & Stratton Single Cyl Intek Models - https://docs.google.com/file/d/0B6Na...RSdWo3ZVk/edit
Micro Trimmer Engine Repair Manual - https://docs.google.com/file/d/0B6Na...80a2tvRVk/edit
Outboard 5HP Repair Manual- https://docs.google.com/file/d/0B6Na...ppWE5pWTg/edit
2-cycle Snow Blower Repair- https://docs.google.com/file/d/0B6Na...RTZzI1dDA/edit
Model 95700, 96700 2 Cycle Engine Service & Repair- https://docs.google.com/file/d/0B6Na...hiTUlfVzA/edit
Briggs And Stratton Twin Cylinder Engines
Opposed Twin L-Head Repair Manual- https://docs.google.com/file/d/0B6Na...NTQUNNR2s/edit
Intek OHV Repair Manual- https://docs.google.com/file/d/0B6Na...A5TGltZEE/edit
Vanguard Repair Manual- https://docs.google.com/file/d/0B6Na...9CWlNwYVE/edit
Common Specifications For Briggs & Stratton Vanguard OHV V-Twin Engines- https://docs.google.com/file/d/0B6Na...dfSEZ5N0E/edit
Common Specifications For Briggs & Stratton Intek V-Twin OHV Engines- https://docs.google.com/file/d/0B6Na...MwZ2Vmb0E/edit
Common Specifications For Briggs & Stratton Twin Cyl Models- https://docs.google.com/file/d/0B6Na...dZbkRVOUk/edit
OHV Vanguard Twin Cyl Liquid Cooled Repair Manual- https://docs.google.com/file/d/0B6Na...xjUEN1WDQ/edit
Briggs And Stratton Triple Cylinder Engines
Vanguard 3-Cylinder OHV LC Diesel- https://docs.google.com/file/d/0B6Na...N3elAxd2M/edit
Vanguard 3-Cylinder OHV LC Gasoline- https://docs.google.com/file/d/0B6Na...RBV0JEeXM/edit
Troubleshooting & Reference Guides
Trouble Shooting Carb & Compression- https://docs.google.com/file/d/0B6Na...81S19kMGc/edit
Quick reference Catalog- https://docs.google.com/file/d/0B6Na...81S19kMGc/edit
Oil Capacity Chart- https://docs.google.com/file/d/0B6Na...NzclB5NnM/edit
Electric Motor Repair- https://docs.google.com/file/d/0B6Na...dJaEFzaU0/edit
Power Pack System BE 2010- https://docs.google.com/file/d/0B6Na...FXSi1zbDg/edit
Basic Ignition Wiring Diagram- https://docs.google.com/file/d/0B6Na...EteFVmNDA/edit
Digital Multimeter Tests- https://docs.google.com/file/d/0B6Na...ZPOTJjYVU/edit
Engine Starter Reference Guide For Engines Built After 1976- https://docs.google.com/file/d/0B6Na...VWNUE2YlU/edit
Check Chart For Metric Specs All Common Engines- https://docs.google.com/file/d/0B6Na...R2a3hGVGc/edit
Check Chart For English Specs All Common Engines- https://docs.google.com/file/d/0B6Na...lPVE1Gdm8/edit
Briggs & Stratton Trouble Shooting Flow Chart- https://docs.google.com/file/d/0B6Na...tDTC1tak0/edit
Briggs & Stratton Accessories Catalog- https://docs.google.com/file/d/0B6Na...NQN2Z6bFU/edit
Briggs & Stratton Handymans Repair Book For Older Engines (1919 - 1981)- https://docs.google.com/file/d/0B6Na...NaTzlpWmc/edit
Briggs & Stratton Carburetion Troubleshooting & Repair Procedures 1996- https://docs.google.com/file/d/0B6Na...N2TGJPQkU/edit
Briggs & Stratton Belt Failures Book- https://docs.google.com/file/d/0B6Na...psRGhjODg/edit
Pressure Washer Pumps by Generac- https://docs.google.com/file/d/0B6Na...tFbEllbk0/edit
Alternator Replacement With Wiring Diagrams- https://docs.google.com/file/d/0B6Na...hWUUNyZ1U/edit
Alternator Identification Chart 1- https://docs.google.com/file/d/0B6Na...9YSFRvNWs/edit
Alternator Identification Chart 2- https://docs.google.com/file/d/0B6Na...ppdFBPLTQ/edit
Source- http://www.mytractorforum.com/archiv.../t-242387.html
The Following 14 Users Say Thank You to Doc Sprocket For This Useful Post:
88nightrider (04-15-2014), DrBob762 (05-28-2014), Ericg (05-29-2016), itsid (09-14-2013), JTSpeedDemon (06-15-2019), Kartorbust (06-21-2019), kieranruffell (01-21-2014), machinist@large (10-27-2013), Midian Yoshi (07-24-2014), ond (09-03-2018), Oxymoron (09-16-2013), sideways (07-20-2017), tuneman (05-01-2014), zbuck (09-14-2013)
Old 10-27-2013, 03:57 AM
offroada offroada is offline
Hi all, Just wondering if anyone has a manual for a Kohler 8 hp electric start engine, it is an oldish engine and has an alternator built in that requires a regulator that I have to get the details of so I can run lights on my buggy.
Cheers
Old 10-27-2013, 10:54 AM
OzFab's Avatar
OzFab OzFab is offline
I understand your reason for posting here but, IMHO, your enquiry will get more attention in its own thread
The Following User Says Thank You to OzFab For This Useful Post:
offroada (10-27-2013)
Old 10-27-2013, 10:00 PM
ok thanx i will start one.
