Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Closed Thread
Old 07-31-2019, 04:57 PM
Brycen W Brycen W is offline
Junior Member
Default I can't remove my flywheel no matter what I do.
Hello. I have a predator 212 and I'm trying to add an 8 degree advanced timing key and I can't get my flywheel off. I have tried banging my crank and using pressure from a screwdriver on the flywheel and even bought a puller and nothing is working.
Old 07-31-2019, 07:00 PM
mrdeadman1 mrdeadman1 is offline
usually I lay it on it's side and put a small pry bar under the flywheel them smack the crank with the nut on it with a hammer
Old 07-31-2019, 08:45 PM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
Quote:
What he said. ☝️
Old 09-05-2019, 07:10 PM
dheeraj.gosala dheeraj.gosala is offline
Junior Member
Brycen, Have you been able to remove the flywheel? I seem to have the same problem- I tried to wedge the flywheel out with a few screwdrivers from all sides and banged on the crank nut with a hammer, but to no avail.
I have all the other parts off, including the piston and con rod. Is there another way to remove the flywheel from the other side?
Thanks in advance!
Old 09-06-2019, 12:09 AM
Just finished taking off a flywheel. I use a 2.5lb rubber mallet and a pry bar. Engine with crank facing down, sides supported but crank free floating. It takes a few whacks before it frees up.
Old 09-06-2019, 05:51 AM
anickode's Avatar
anickode anickode is offline
Anybody ever think to try a flywheel puller?
"Well that would be a bomb."
Closed Thread
