Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Closed Thread
Old 07-08-2019, 04:34 PM
Mrflyingdonut Mrflyingdonut is offline
Junior Member
Default I was given this engine and want to put it on a go kart
I was given this 20 hp engine and want to know the best way to put it on either my golf cart or a go kart, should I be using a tourqe converter? How can I get a reverse gear
Sent from my SM-G950U using Tapatalk
Old 07-08-2019, 04:39 PM
mckutzy mckutzy is online now
Your in snow machine territory with that motor...
It has a 1" shaft, its bigger than most other CVT. Itll also have to handle the power of the engine...
For the most part it wont be easy and/or cheap...
Old 07-08-2019, 05:57 PM
JTSpeedDemon's Avatar
2019 Build Off Winner!
DOH! JEALOUS!! A 20 HP Briggs Vanguard for FREE!
You dang lucky!
Currently Flathead-Crazed
Old 07-08-2019, 06:18 PM
Junior Member
Quote:
You dang lucky!
I know, very lucky, now I just need to know if a 40 series tourqe converter is good enough
Old 07-08-2019, 07:15 PM
anickode's Avatar
anickode anickode is online now
Not really. That's beyond the design rating of a 40 series. If you were gentle on it it would probably be fine, but who's gonna take it easy on a 20hp go kart, right?
"Well that would be a bomb."
Old 07-08-2019, 08:04 PM
Kartorbust's Avatar
Kartorbust Kartorbust is online now
I'd look at a Comet 780, it'll be quite expensive, but it'll handle the power well. That Vtwin also has some modification support within the race mower community. So billet rods, flywheel (with starter ring gear), cams...can be had for it.
  #7
Old 07-09-2019, 12:03 AM
landuse's Avatar
landuse landuse is offline
A comet 40 is not really suited for 20HP. Look at the Comet 780 and maybe some snowmobile TC's if you can get them to fit
  #8
Old 07-09-2019, 04:49 AM
Junior Member
So a comet 780 would do it, what are my options to get a reverse gear?
  #9
Old 07-09-2019, 06:23 AM
BigWes's Avatar
BigWes BigWes is offline
I wish I had it.
This ain't rocket science boys!!!
  #10
Old 07-09-2019, 06:31 AM
anickode's Avatar
A reverse gearbox. Probably need to find one from an ATV.
  #11
Old 07-09-2019, 08:02 AM
Junior Member
Quote:
Would it be better just to get a whole atv transmission
  #12
Old 07-09-2019, 09:48 AM
I would think taht a setup like what 420Racer has done with an electric setup....
http://www.diygokarts.com/vb/showthread.php?t=41402
Gear as normal, then have a separate reverse circuit.....
Youll have the engine to keep a charge in the battery, and also the power to go forward....
This is going to rock......
  #13
Old 07-09-2019, 10:17 AM
Junior Member
I guess that's one way to do it, I'll keep that in mind, I see where this guy used a 1992 Polaris atv trail boss transmission, do you think that would handle 20 hp?
http://nissannut.com/manco_2/
  #14
Old 07-09-2019, 10:37 AM
Budget GoKart's Avatar
Budget GoKart Budget GoKart is offline
Aka a kenbar
Lucky i want one but if you can find a cheap knock off 780 or 40 series i would say be careful and dont kill yourself i have a 30 series on a 13.5hp subaru so i gotta go easy on it
I gotta fix my flathead collection
  #15
Old 07-11-2019, 02:07 PM
Junior Member
Starting to think reverse is more trouble than it's worth
  #16
Old 07-11-2019, 02:59 PM
For the most part.. Ya it's a hassle to build or accommodate...
  #17
Old 07-12-2019, 01:25 AM
landuse's Avatar
This
  #18
Old 07-12-2019, 05:05 PM
Joe-405's Avatar
Joe-405 Joe-405 is offline
2018 Buildoff Winner ! 😎😎
If you leave the engine bone stock and gear it right I personally think a genuine comet 44 series will work. NOT a knockoff. And a lighter kart.
My modded 420cc has a 44 magnum and was fine til I reved it past 5,000 rpms.
Closed Thread
