Go Back   DIY Go Kart Forum > Other Stuff > Off Topic Forum
Closed Thread
Old 02-13-2019, 09:20 PM
shady's Avatar
shady shady is offline
I like touching girls hip
Default Advice on natural gas generator
Most of the threads I found here involve converting a gasoline generator to natural gas, or propane.
One issue is that NG generators run hotter than gas ones and some say this might void a warranty.
I would like a generator designed as an NG generator from the get-go but would allow conversion to propane as a backup. Conversion to tri-fuel to add gasoline would be a plus but not a determining factor.
I am also concerned with noise levels as I am on a 5,000 sq ft postage stamp sized lot so neighbors are close.
I confess I haven't down my homework yet as to size but I only really need it to run two recirculating pumps on my NG furnace (one pump was replaced a few months ago and the other is an original and probably a power hog so it would have to be replaced) and a modern energy efficient refrigerators. Oh, and my wife says it needs to also run a hairdryer. LOL, I'm thinking 3,000kw would be more than enough.
Can someone provide any recommendations on NG generator makers, brands and models, or why my approach is not practical?
I would be glad to collect user's opinions about models represented in this review:
https://wisepick.org/best-tri-fuel-generator/
Thanks in advance!
Old 02-14-2019, 06:48 AM
ezcome-ezgo's Avatar
Is price an issue?
Old 02-14-2019, 07:16 AM
itsid's Avatar
itsid itsid is offline
Quote:
Is a 3MW generator not a tiny hair too big for hair dryer and a fridge?
I mean we talk 20cylinder 4000 horse diesel here
I know double-triplet-error
but I just imagine you come home one day and see this happening
because you ordered a 3000 kilowatt (see the two triplets?) generator:
shady (02-15-2019)
Old 02-14-2019, 12:58 PM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is offline
Pro Junk Collector
how often will this generator be used?
Old 02-14-2019, 03:54 PM
Tpdingo Tpdingo is offline
There was a clearance sale at Costco on hair dryers....and he better be able to power all of them at once.
Give a wrench long enough and WD-40, and I can remove the world's rusty bolts.
The Following User Says Thank You to Tpdingo For This Useful Post:
shady (02-15-2019)
Old 02-14-2019, 06:02 PM
Panhead5496's Avatar
Panhead5496 Panhead5496 is offline
When I saw this thread title the first thing that popped into my mind was "just eat a lot of baked beans, they are good for making gas"
The Following User Says Thank You to Panhead5496 For This Useful Post:
shady (02-14-2019)
  #7
Old 02-14-2019, 06:42 PM
shady's Avatar
Quote:
Approximately 1-2 times per week for ~6h
---------- Post added at 08:42 PM ---------- Previous post was at 08:41 PM ----------
Quote:
Quite effective and cheap method
I keep the finger on the pulse xD
There is only today for living
  #8
Old 02-14-2019, 07:52 PM
Kartorbust's Avatar
Kartorbust Kartorbust is online now
In all honesty I would look at a name brand like Generac. I haven't looked at the cost difference between Natural Gas or LPG (propane), or to run both, usually theres a jet difference I believe can't quite remember for sure. http://www.generac.com/all-products/...at=217&cat=249
They do have a calculator to help you on sizing.
The Following User Says Thank You to Kartorbust For This Useful Post:
shady (02-15-2019)
  #9
Old 02-14-2019, 08:23 PM
Pro Junk Collector
With that much use id look into a stationary low rpm unit...the 3600rpm portable generators will not hold up in the long run.
The Following User Says Thank You to Kaptain Krunch For This Useful Post:
shady (02-15-2019)
Closed Thread
