Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Closed Thread
Old 01-31-2019, 06:06 AM
67StingrayJ 67StingrayJ is offline
Default single sided swing arm
I’m trying hard to design a single sided swing arm rear suspension like shown below.
https://www.offroadfabnet.com/forums...ad.php?t=11315
The biggest problem I’m having is lack of parts. Sure there are gobbles or parts out there but not what I’m after. I want a good hub that I can grease easily with a disc brake hub attachment capability. The axle I’m looking for needs about 1.250” of 3/4” threads, followed by a 1” spline that will fit the drive hub. Then it eventually needs to step up to a 1-1/4 diameter with a better means of attaching a sprocket. I’m not a fan of the China supplied parts like hubs, axles or wheels but I’m not opposed to them if I can find something that is universal to some degree. I been finding mixed results on bolt hole patterns for wheels, disc brakes and sprockets and I’m getting frustrated. MFG these days want to sell you a part based on what it fits rather than give you a set of detailed specifications or drawings to work from. I want to get something that will enable me to install a better tire and wheel later on, as well as easily found sprockets that will bolt right up. So I been spending a lot of time on ATV forums trying to find out what the typical bolt hole pattern is for say a Yamaha or Polaris or Honda ATV. Mainly sprockets, disc brakes and wheels. But I’m also interested in a good size chain too. It sounds like a 420 chain is common. Or at least a 1/2” pitch chain. If anyone has a good lead on these things, axle, wheel hub, disc brake hub and sprocket hub let me know.
Old 01-31-2019, 06:35 AM
ezcome-ezgo's Avatar
I'd start here.
Old 02-01-2019, 09:00 AM
Quote:
Originally Posted by ezcome-ezgo View Post
I'd start here.
Yeah, thanks for being so helpful...
Old 02-01-2019, 09:31 AM
itsid's Avatar
itsid itsid is offline
No HiJacking!
•MOVED•
Closed Thread
