Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Closed Thread
Old 01-28-2019, 06:19 PM
G-Gaurd G-Gaurd is offline
Junior Member
Default 6 pin CDI box
Hey hey
I have a Carter 150cc buggy that I got cheap ..... it's missing the ignition switch and emergency kill switch
Today I went and got a 3 wire ignition switch with key but the place didn't have a kill switch so I'll have to improvise
Wire diagrams show me the ignition switch recieved the Y/R .. G/W .. and G wire
The kill shows me the G/W and the B/W wire
The B/W wire goes to the 2 point connection on the CDI box .... should there be power going to the B/W wire ?
I want this motor to spark so I can start the engine
Thank you for any and all assistance
Old 01-29-2019, 04:18 PM
pulsar2121 pulsar2121 is offline
Junior Member
I found this thread on an ATV forum that should help point you in the right direction. I feel your pain though, I went through the whole electrical system on a scooter with the same engine before I figured out why it wouldn't start.
https://atvconnection.com/forums/kid...-question.html
Old 01-30-2019, 03:13 PM
Junior Member
Awesome
On my connector there is only 3 pins being used .... there are apparently 2 ground source wires... green and G/LG ... I wonder if since the G/LG wire is missing would cause me no spark ?
Old 01-30-2019, 04:06 PM
Junior Member
It is possible. I'm not sure how the rest of the vehicle is wired, but it'd by with a try running a jumper wire from the first ground over to the second and then re-checking the spark.
Closed Thread
