Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Closed Thread
Old 01-05-2019, 11:10 PM
XsamX1987 XsamX1987 is offline
Junior Member
Default Replacemnt nut for Motor to keep Sprocket in place
Hello all, ok I need a replacement nut for my motor as I kind of damaged it, I know I need a nut with reverse thread but that is about it, I don't know much about sizing here is some information on the motor to help
Measurement
mm
inches
Greatest Distance Between Fixing Holes (Centre of Eye to Centre of Eye)
115
4.53
Sprocket Thickness
Sprocket Diameter (Tip of Tooth to Tip of Tooth)
25
0.98
Length of the Shaft on Which the Sprocket Sits
23
0.91
Wiring Length (approx.)
590
23.23
Diameter of Fixing Hole(s)
9
0.35
Smallest Distance Between Fixing Holes (Centre of Eye to Centre of Eye)
56
2.2
Barrel Diameter
108
4.25
Barrel Length
135
5.31
Shaft Diameter
12
0.47
Voltage
24 v
Wattage
500 w
Rated Current
26.7 a
Rated Speed
2500
Chain Size
6mm (25H)
Number of Teeth
11
Drive Type
Sprocket
Brushed or Brushless?
Brushed
Model Number
ZY1020
Old 01-06-2019, 08:55 PM
itsid's Avatar
itsid itsid is offline
measure the shaft (it'll be metric sooo use a metric caliper for that)
it'll be 10mm.. (well SHOULD be)
but maybe you'll have an oddling with just an 8mm diameter shaft.
And then, buy such nut (if you say its reversed, then yeah a left hand nut)
And that info you posted appears to be copied from electricscooterparts.com
And funny enough, if you google "zy1020 shaft nut"
you'll find that exact place selling shaft nuts for zy1020 motors..
https://electricscooterparts.com/sprockethardware.html
who'd thunk
XsamX1987 (01-07-2019)
Old 01-07-2019, 01:09 PM
Junior Member
who'd thunk
Thank you for taking the time to help me
have a nice day
Closed Thread
