Closed Thread
Old 10-08-2018, 08:32 AM
subarumafia subarumafia is offline
Junior Member
Default Streaker torque converter questions
I've got a Streaker fun Kart I'm trying to get sorted out. Its got 22" tall tires in the rear, a 60 tooth sprocket on the drive shaft and I just installed a predator 212 engine with a 10 tooth centrifugal clutch. This gear ratio doesn't work. The Kart has a hard time taking off and reaches frightening speeds. Thinking the Kart may have had a torque converter on it in the past. The question is will a torque converter provide more reduction? If not, should I just go to a larger driven sprocket?
Thanks
Chris
Old 10-08-2018, 08:49 AM
frostyflammable's Avatar
frostyflammable frostyflammable is offline
Yes, for the 212 a 3/4in shaft, you will need a 30 series torque converter. With 6:1 ratio with 22" tires may be pushing it but someone will I am sure give you a better answer. I would go away with the clutch and put a TC on there as it will give you even more reduction on the low end. I forget the actual reduction on the low end but it also gives you a 1.1 overdrive.
--Dan
Old 10-08-2018, 09:13 AM
Junior Member
Thanks for the reply Dan. I'm sure the kart is supposed to have 22" tires because its level with them on there. I tried some smaller tires I had kicking around and it pointed up hill. I've got a 301 predator as well. Would that be a better motor choice? Could it just be an issue of not enough torque?
Thanks
Chris
Old 10-08-2018, 09:22 AM
I would still go with a TC even with the 301. Although with the 301 you have a 1" shaft so a 40 series would be recommended although probably could get away with a 30 series with a 1" driver unit. If it were me I would do TC no matter what, you will be much happier with it.
--Dan
Old 10-08-2018, 09:27 AM
Junior Member
I think I'm decided on the torque converter. I'm just not sure if it provides a lower ratio or not. I'd like to use the predator 212 if possible. I like the idea of the smaller hot rod motor. Plus I've got a bunch of them and only one 301 which I wanted to use on a 2 man Kart project I've got going on. Can someone chime in and tell me exactly what kind of reduction the torque converter will give me?
Thanks
Chris
Old 10-08-2018, 10:21 AM
The TC does provider a smaller take off ratio... I believe (do not quote me on this) that the take off ratio is 2.7:1 on top of the 6:1 already on the kart from jackshaft to axle. The overdrive is .9:1 if my memory serves me right... so off the line you would have the 2.7:1 and the 6:1 reduction. If I remember how to calculate compound gears you should have 16.2:1 off the line with the TC and 5.4:1 in overdrive. With 22in tires that would mean a top speed of 44mph assuming governor is still in tact (3600rpm) and the engine has enough umph to get to the speed.
--Dan
  #7
Old 10-08-2018, 10:43 AM
Junior Member
Thanks Dan. So all said and done. In your opinion is that a functional set up with the TC. Do you think that the Kart will have enough low end grunt to work as the manufacturer intended?
Chris
  #8
Old 10-08-2018, 10:58 AM
itsid's Avatar
itsid itsid is offline
2.7 and 0.9 are correct for a series 30 with 6" driven unit (the TAV Kit for example)
BUT 6:1 is still a bit of a stretch for wheels that size..
you might need a taller rear sprocket to lower the gearing down further (7.5:1 recommended)
6:1 is a good value for 18" rear wheels (WITH TC!) not so much for 22" I'm afraid
PS if you want to play with numbers and inbetweens:
visit app.kartcalc.net with your phone and click on quickcalc
  #9
Old 10-08-2018, 11:18 AM
Junior Member
Ok, Thanks for the help. So I think I have space for a 70T sprocket. The problem is I cant seem to find a 41 pitch 70t sprocket with matching hub on any of the go Kart sites. Also struck out on amazon and Ebay.
Thanks
Chris
  #10
Old 10-08-2018, 01:39 PM
Junior Member
Just found a post on forum about literally the exact same thing with exact same Kart. The Kart came from the factory in this configuration. How could it not work?
Chris
  #11
Old 10-08-2018, 02:18 PM
J.S.@SMS's Avatar
J.S.@SMS J.S.@SMS is offline
Road Hazard
I guess that you found my thread. I've yet to solve this problem on mine. I thought of using a jackshaft, however I would need two to align the sprockets. The two solutions that I am thinking about are switching to 18 x 9.50 - 8 inch Carlisle Knobbys (similar to factory tread pattern), or ordering a live axle online and using a larger sprocket.
  #12
Old 10-08-2018, 03:15 PM
Junior Member
Two problem here. I have found only one larger sprocket. Go power sports has a 72T aluminum sprocket that will barely fit in the frame and doesn't get you to the desired ratio. I don't think anyone makes one bigger one but even if they did it just wont fit. Going to smaller tires is going to put your Kart in an uphill stance. I tried it. Its goofy. Plus the sprocket drags on everything. I'm going to try a 301 predator and 30 series torque converter on mine. I'm thinking this Kart must have come with a bigger motor. Only way this configuration works.
Thanks
Chris
---------- Post added at 01:49 PM ---------- Previous post was at 01:32 PM ----------
I'm getting ratios between 16.2 to 1 and 5.4:1 in the calculator. Is that likely to work with the predator 301 motor?
Chris
---------- Post added at 02:03 PM ---------- Previous post was at 01:49 PM ----------
KartInfo by kartcalc.net:
Code:
KART
Kartname : Streaker RW diameter : 22 in Weight : 450 kg
ENGINE
Engine type : Predator 301 HP : 8 Torque : 10.5 ftlb | 14.24 Nm RPM : 4000 Governor removed : false
TRANSMISSION
System : Torque Converter TC type : series 30 6" driven TC sprocket : 10 Axle sprocket : 60 Final Ratio : 6:1 Lowest Ratio : 16.2:1 Highest Ratio : 5.4:1
PERFORMANCE
Min Torque : 56.72 ftlb | 76.9 Nm Max Torque : 170.15 ftlb | 230.69 Nm Acceleration : 3.41 fpsē | 1.04 m/sē Top Speed : 48.48 mph | 78.02 km/h
---------- Post added at 02:15 PM ---------- Previous post was at 02:03 PM ----------
The app suggested a final ratio of 6.8:1. We are getting a lot closer.
Chris
  #13
Old 10-08-2018, 03:23 PM
itsid's Avatar
Quote:
Chris
CHICAGO BULLS SHIRT!
The KenBar Streaker came with 13" wheels all around (13x5 on 6" rims)
and a simple centrifugal clutch not a Torque converter
  #14
Old 10-08-2018, 03:38 PM
Junior Member
Sid,
So I'm very likely completely wrong but I'm thinking there is more than one streaker model. I know the DD9 streaker came in a similar but 2 seater config. Looks like J.S. has exactly the same set up as mine. I'm also seeing a lot of pics that look like mine online. My frame wouldn't work with 13" wheels. I know I'm missing something here. I did some calcs and my final drive works out perfectly with 9hp. I'm gonna try my predator 301 stage 1 and see if I can get the thing moving. Am I missing something?
Thanks
Chris
  #15
Old 10-08-2018, 03:42 PM
Tpdingo Tpdingo is offline
I know it was very popular to put on 18" rims and 6:1 ratio with a T/C, so that is a possible setup it could have come with.
Give a wrench long enough and WD-40, and I can remove the world's rusty bolts.
  #16
Old 10-08-2018, 04:14 PM
J.S.@SMS's Avatar
Road Hazard
Not sure if my engine is factory (no reason it wouldnt be) but my kart has a Tecumseh OHH60 which last I checked is a 6.0 horse 195cc engine.
  #17
Old 10-08-2018, 04:23 PM
Junior Member
J.S.
You're issue is that you are not getting the top speed you want? Does it take off ok and run ok? Do you burn up belts?
  #18
Old 10-08-2018, 04:38 PM
J.S.@SMS's Avatar
Road Hazard
The engine runs great, the acceleration could use some work (my stock minibike could beat it in a race), and my top speed is not where it is capable of going. But I have yet to burn up a belt.
However I am using a brand new torque converter from gopowersports (since the old one blew up).
  #19
Old 10-08-2018, 04:45 PM
Junior Member
Yeah, I'm thinking the only solution is more HP.
  #20
Old 10-08-2018, 06:22 PM
J.S.@SMS's Avatar
Road Hazard
That's something that i'm thinking of. I am currently trying to decide between a Duromax XP7HPE and a Tillotson 212 with e-start. The Duromax has 7hp (1 more than the original), and an electric start. However the Tillotson has 10hp (4 more than stock). I'm leaning more toward the Tillotson ($250) than the Duromax ($200), since I feel that 3 more horsepower is worth $50.
But for you I would hope that a predator 301 has enough power to move this kart. However if I were you I'd use a 40 series instead of a 30 series.
Closed Thread
