Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Closed Thread
Old 08-29-2018, 08:05 AM
transam400 transam400 is offline
Junior Member
Default Looking for help on tires
Hi,
I am building a custom pedal car, and need help finding a specific size tire. I have spent a lot of time researching but have come up empty handed. Figured I would join here and ask the pros.
I'm looking for a slick tire that is between 7"-8" tall and around 3"-5" wide. Does a tire like this exist? If so, what size would it be? I'm hoping to find a cheap used set with rims.
Something with a profile like the attached as it is a vintage build.
Thanks
The Following User Says Thank You to transam400 For This Useful Post:
gman3850 (08-31-2018)
Old 08-29-2018, 11:30 PM
landuse's Avatar
landuse landuse is offline
Welcome to the forum. I am sure someone will be around soon to help you
The Following User Says Thank You to landuse For This Useful Post:
transam400 (08-30-2018)
Old 08-30-2018, 01:25 PM
Junior Member
Quote:
Thanks, I hope so! I spent a lot of time searching the internet but came up empty handed. Looking to put this pedal car together for my first born who will be here any day now!
Old 08-30-2018, 03:10 PM
ezcome-ezgo's Avatar
Although I have not specifically found what you are looking for, perhaps the direction you need to go is 1/5th scale RC vehicle parts. Keeping in mind that 7 inches is roughly 177mm, there does seem to be some selection out there. It's the 7" outer diameter detail that is challenging.
Old 08-30-2018, 07:50 PM
itsid's Avatar
itsid itsid is offline
7" OD is available... but not in 3-5" width I'm afraid (less than 2" usually)
can be found on motorized skateboards [offroad type]...
yes there are maxxis slicks for that as well
Some mobility scooters have fairly small wheels in the 7-8" range, but none I know actually has wide slicks.
So you have to make a decision I guess..
Do you care about the OD or the width..
since you can have either, not both as it seems.
10" OD is easy.. just saying
Smallest slick I can find is the CST (chengshin tyre) C-190
a classic kart slick
in 9 x3.5 - 4
9" tall (just under as always) 3.5" wide for a 4" rim.
Oh also available as carefree (solid tyre):
https://www.ebay.com/itm/9x3-50-4-Ca...-/171322138687
OH look!!
indeed there allegedly IS a smaller CST C190 ...
https://www.ebay.com/itm/CST-C-190-S...gAAOSwQFhbXgGX
8" tall (spot on!) 3" wide (spot on!) still for a 4" rim...
I am baffled!
as it is listed on their website.. I'm confident the tyre DOES EXIST!
https://www.csttires.com/int/tire/c190/
The Following 3 Users Say Thank You to itsid For This Useful Post:
Joe-405 (08-30-2018), Nosandwich (08-31-2018), Panhead5496 (09-06-2018)
Old 09-02-2018, 09:03 AM
Junior Member
Thanks for the replies.
I would have to stick with 8” tall or less as I don’t want to modify the car body.
It looks like the tires you posted could work. I will start looking around for them.
Thanks again
  #7
Old 09-02-2018, 09:12 AM
anickode's Avatar
anickode anickode is offline
Just remember, the bigger the contact patch, the more friction, particularly when cornering. Could get hard to pedal with 3-5" wide slicks, especially if it's for little legs.
That's why pedal cars usually have very skinny and/or very hard (plastic) wheels. That, and weight, which also makes it harder to pedal.
"Well that would be a bomb."
  #8
Old 09-18-2018, 09:16 PM
Junior Member
Thanks everyone for the help. I was able to find the tires I was looking for.
Closed Thread
