Go Back   DIY Go Kart Forum > Announcements & Suggestions > FAQ & Articles
Closed Thread
  #41
Old 11-25-2011, 09:29 AM
used2jeep used2jeep is offline
Quote:
Originally Posted by ironman View Post
yea gas pedal could be done alot better but i was gettin in a rush on it.
Is there any pedal extension on the bottom side of the frame? Maybe you could put the spring down there (just have it run to the front of the cart)?
  #42
Old 01-27-2012, 03:07 PM
Quote:
Originally Posted by slideways View Post
lawn mower mode...kart mode.
  #43
Old 03-27-2012, 01:10 PM
kartfanatic kartfanatic is offline
Junior Member
Default hmm?
can you weld on that without taking off the coil or doing anything special? i have one too and i need to weld on the kart frame..
  #44
Old 03-28-2012, 05:03 AM
Doc Sprocket's Avatar
Quote:
You'll want to start a new thread on this question, with some detail.
  #45
Old 09-24-2012, 01:55 PM
tx7750680 tx7750680 is offline
this is my throttle set up on my 6.5 Predator. I loosened the throttle nut, and added the spring and it returns great. When I mount it ill connect the throttle cable and go.
Closed Thread
