Old 08-30-2019, 04:55 PM
bobdabuilder bobdabuilder is offline
Default 50mm axle
I'm building a 2 seater 1000cc kart. I'm trying to find a solution for the axle. I need a 50mm axle but the longest one I can find is 1040mm, roughly 40 inches long. Any ideas on who makes a longer axle? Or other ideas on another solution?
Old 08-30-2019, 05:47 PM
Kartorbust's Avatar
Maybe contact a machine shop and bring them the alloy metal you want turned down for the axle.
Old 08-30-2019, 06:02 PM
Yea I thought of that. I was hoping someone might make a longer one or have another idea. I know a longer axle may require some extra support bearings.
Old 08-30-2019, 07:13 PM
I'm confused....
Do you mean 50 inches??
Currently Flathead-Crazed
Old 08-30-2019, 11:49 PM
950speed's Avatar
950speed 950speed is offline
I think he needs a 50mm diameter, and longer than 1040mm, longer than 40 inches?? I think?
Old 08-31-2019, 02:08 AM
Mrmonk7663 Mrmonk7663 is offline
50mm is the common size for the Racing karts since I believe the late 90s. 1020-1040 is the size most of those karts use. You would be better off contacting one of the manufacturers of the axles and see if they can do a custom length.
Old 08-31-2019, 03:42 AM
itsid's Avatar
itsid itsid is offline
Originally Posted by JTSpeedDemon View Post
I'm confused....
A perfect example why america's ignorance to the metric system
is a baaaad idea..
innocent kids are likely to get bullied from all around the world for making an utterly stupid comment like that!
bob, I'll see what I can find..
I think I saw a race-kart style sbs two seater once for some track day sightseeing..
I think it was 20-25cm wider..
[EDIT]
So I checked the two karts I had in mind (Sodi and Rimo)
Sodi 2Drive is actually just 1450 mm wide... so that'd be a std length axle I'm afraid
the Rimo Twin is 1530 wide, wider but by far not as wide as I thought it was ...
frankly, I doubt it has a wider axle with just the 80mm excess in width..
more likely they included the bumpers that sodi likely ommitted in measurements
maybe extended hubs *shrugs*
What size would you need and what keying is required?
since while it's easy to just cut some tube to size,
that wouldn't still make it a go kart axle..
but if you need a special size, maybe contacting righetti ridolfi could solce your problem,
they make kart axles on a daily basis maybe they can cut one oversize one for you and add the requied keyslots'n'holes
mckutzy (09-01-2019)
Old 09-01-2019, 09:09 AM
anderkart's Avatar
anderkart anderkart is offline
You could buy or build longer wheel hubs, here's a link to 50mm. hubs available in a 5-7/8" width:
https://cometkartsales.com/Magnesium...Wheel-Hub.html
The Following User Says Thank You to anderkart For This Useful Post:
Mrmonk7663 (09-02-2019)
Old 09-01-2019, 12:41 PM
is a baaaad idea..
Lack of info confused me. Now I get that he's looking for 50mm dia. axle, longer than 1040mm. The OP was kinda confusing, partially because he didn't specify exact wanted length.
I am not confused by the metric system, just when it is talked about unclearly.
---------- Post added at 01:41 PM ---------- Previous post was at 01:40 PM ----------
Anyway, I'm outta this thread.
