Old 06-11-2019, 06:32 PM
Ltcjc Ltcjc is offline
Default 5" 2 piece steel cart wheels
I bought a $50 frame with 4 steel (2 part) wheels - all flat and rusted out. The 5/8" hubs were good. I'm trying to find replacement wheels but am confused by the center hub portion. The tires were 4.10 - 3.50 - 5. Question: can I buy just the steel rims, and will the hubs fit? Can I put 6" wheels on these hubs (for the rear tires only)?
Here's a couple of pics of the wheel and hub.
Old 06-11-2019, 06:51 PM
Follow up: is there a "hub" to convert larger golf cart tires/rim to fit a 5/8th axle? If so, where can I find the part? Thanks.
Old 06-11-2019, 07:04 PM
Budget GoKart's Avatar
Aka a kenbar
Uh id say its best to buy some ebay wheel hubs ive had mine explode before
Why does my go kart hate me? Oh yea never mind...
Ltcjc (06-11-2019)
Old 06-11-2019, 08:09 PM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
As long as you buy the right rims with the same bolt pattern measurements, yep.
Don't buy just any run-of-the-mill rims, buy some meant for go karts.
Try the usual:
BMI Karts
Go PowerSports
MFG Supply
Etc....
I love the small tires though, the 4.10x3.50-5", or the same in 4" or 6".
The Following User Says Thank You to Hellion For This Useful Post:
Ltcjc (06-11-2019)
Old 07-01-2019, 09:02 PM
Kentucky Boy's Avatar
Kentucky Boy Kentucky Boy is offline
Those wheels look like Swiss cheese. Iím impressed. I second BMI. They have some good wheels.
The Following User Says Thank You to Kentucky Boy For This Useful Post:
Ltcjc (07-02-2019)
Old 07-01-2019, 09:28 PM
itsid's Avatar
itsid itsid is online now
Not a chance!
That is a Carter clover hub, with a bolt hole pattern that's unlike any other known pattern
Soo if you cannot find Carter rims, you cannot make use of the hub!
(and vice versa: if you cannot find that Carter hub, you cannot reuse those wheels)
reliable go karts was the last known to me source for carter spec'ed rims..
No longer available (for more than 4yrs now)
Sooo in case you cannot find them on ebay or Craigslist or alike,
you will be out of luck
ONLY solution:
buy new rims with matching hubs.. but I bet you can sell that hub for a small fortune on ebay
Ltcjc (07-02-2019)
Old 07-02-2019, 03:20 AM
Hellion's Avatar
Originally Posted by itsid View Post
Not a chance!
Good call, you old bookworm.
What is that bolt pattern in inches, por favor?
Sure is interesting that there's variation in "generic go kart parts".
Must be used in some other applications like lawn mowers or the like.
Old 07-02-2019, 06:12 AM
itsid's Avatar
Carter G308 hub
was 3/8" bolt holes on a 3 3/32" bhc IIRC
The Following 2 Users Say Thank You to itsid For This Useful Post:
Hellion (07-02-2019), Ltcjc (07-02-2019)
Old 07-02-2019, 09:46 AM
You were right, I had to buy 4 hubs, 4 wheels/tires, but it's all working out. I dumped the H/F wheels due to safety concerns (thanks for the advice). Waiting for the final parts to get up and running. :0)
---------- Post added at 10:46 AM ---------- Previous post was at 10:44 AM ----------
As an after thought, I now have 4 "Carter clover hubs" if anyone is in need. Let me know.
The Following 2 Users Say Thank You to Ltcjc For This Useful Post:
Dwoody (07-23-2019), Hellion (07-02-2019)
Old 07-03-2019, 12:49 AM
landuse's Avatar
landuse landuse is online now
Those hubs are gold. Someone will want them I am sure
  #11
Old 07-03-2019, 02:00 AM
pRoFiT's Avatar
pRoFiT pRoFiT is offline
Can't buy it?, build it!
People still buying HF wheels.
My modified hubs are working great but the original tires lasted 30 minutes.
2016 diygokart Contestant http://www.diygokarts.com/vb/showthread.php?t=33422.
  #12
Old 07-03-2019, 02:14 AM
Hellion's Avatar
Originally Posted by pRoFiT View Post
People still buying HF wheels....
I'm between karts at the moment, but as soon as I get one operational I'm buying a pair just to watch them die. I got to see what the hype is all about...
  #13
Old 07-03-2019, 10:10 AM
Kill them with a (very short) burnout....
Just out of hatred.
Currently Flathead-Crazed
Hellion (08-14-2019)
