Old 07-13-2012, 03:43 PM
r_chez_08's Avatar
r_chez_08 r_chez_08 is offline
Should be in the shop...
Default Engine Dies On Tight Turns Or Bumps? Read This!
If your engine cuts out on bumpy ground or corners, or you cannot start your engine after filling with the correct amount of oil then try disconnecting the low oil
The engine in the video is a Honda gx200 6.5hp clone engine.
The oil level switch is activated by a float.
When this float goes below a certain level the switch is activated to prevent the engine running with low oil.
However, when cornering or going over bumps this can cause the oil to slosh within the crank case and the float to bump up and down, activating the switch as if the oil level is low.
Therefore for karting uses we generally disconnect or fully remove the low oil sensor to stop the engine cutting out. If the sensor is removed, the hole can be plugged with a short bolt of the correct diameter.
Be sure to regularly check the oil level and condition after disconnecting or removing the low oil sensor, otherwise you could severely damage your engine. Many components can seize or wear rapidly within the motor with poor quality or incorrect grade oil, or worse, too little oil.
My process of thought:
Anyone can drive a fast car, few can drive a car fast.
The Following User Says Thank You to r_chez_08 For This Useful Post:
mason (06-04-2013)
Old 07-13-2012, 04:59 PM
souperman000's Avatar
souperman000 souperman000 is offline
same video, just so people can watch it on this site.
It's hard to help people that won't help themselves.
The Following User Says Thank You to souperman000 For This Useful Post:
r_chez_08 (07-14-2012)
Old 07-14-2012, 12:18 PM
r_chez_08's Avatar
Thanks toystory_4wd for stickying this! I will add some pics and more info tonight.
Old 09-09-2012, 03:23 PM
Ronaldraasch2000 Ronaldraasch2000 is offline
Hey gents could a go kart engine have a vacuum problem in the gas tank? I have a predator 6.5 hp 212 cc engine on my go kart . It dies after I ride up the road. I try the restart it and it starts then dies as if it doesn't have gas . I then open the gas tank and shut it again and it seems gas is now in the carb and it runs the same distance and dies again. I did take off the oil level gauge per the video but it still did this gas scenario. Any advice?
FYI I thought this thread could help since it is on a bumpy road
Old 09-09-2012, 03:41 PM
Doc Sprocket's Avatar
Yessir, it certainly can. The gas cap should be vented to prevent a vaccuum, which will kill fuel flow. If that vent is plugged or otherwise not working, you will have the problem you describe.
The Following User Says Thank You to Doc Sprocket For This Useful Post:
Ronaldraasch2000 (09-09-2012)
Old 09-09-2012, 03:42 PM
r_chez_08's Avatar
Sounds like you found your issue. A new gas cap is $2-4 IIRC.
Maybe try running it without the cap on (carefully) first, as it could be a clogged fuel passage in the carb.
Or take it back to HF if you still have a warranty.
Old 11-23-2012, 08:52 PM
jcampbell jcampbell is offline
Thanks for posting this info. I'll try this and see if it helps. Oddly enough, we were only able to make left turns today (NASCAR-style :lol. Hopefully this is the issue.
Old 02-22-2013, 06:49 PM
captain67's Avatar
captain67 captain67 is offline
I had a similar problem with the 420cc pred. I was told that you need to fill the gas tank no higher than the bottom of the fill filter, not to the full level indicator, which is too high. Once my fuel level got low enough, no more stalling.
