Go Back   DIY Go Kart Forum > Announcements & Suggestions > Introduce Yourself!
Closed Thread
Old 01-13-2008, 08:49 AM
tristram dyer tristram dyer is offline
Junior Member
Default Convert Vertical to Horizontal
hello how do i change vertical power to horizontal???
Old 01-13-2008, 06:20 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
Suspension? Not a GoKart!
Quote:
Depends on what engine you have. Who is manufacturer and what model number is your engine?? Based on what you have, we can answer more clearly.
https://www.youtube.com/watch?v=pzrp0eki0Fo
Old 01-14-2008, 10:14 AM
robin's Avatar
robin robin is offline
if
one was to ad an oil pum would yat be it apart from the carb ?
there's no replacement for displacement
Old 01-14-2008, 03:25 PM
2or3wheels 2or3wheels is offline
i dont kn ow robin, if its 2-stroke then all youd need to do is get the carb upright.
Old 01-14-2008, 05:24 PM
Russ2251's Avatar
So far I have successfully converted 4 different model Lawn-Boy 2 cycle vertical shaft engines to work in horizontal position. An easy undertaking if you understand how/why things work the way they do.
Oil/fuel mixture means all parts are lubricated all the time regardless of shaft orientation. I have seen jugglers use running chainsaws as part of their act.
A vertical shaft 4 cycle engine is very different for a couple of reasons.
These engines rely on a reservoir or sump to supply moving parts with oil.
A typical 3.5 hp Tecumseh uses a pump powered off camshaft which is submerged in oil. An equivalent Briggs and Stratton uses an oil slinger partially submerged in oil.
It seems to me that the B&S engine could be more easily converted as long as oil slinger is making contact with oil. Tecumseh might be a different story in that pump may be left high and dry and unable to pickup oil.
See my other posts relative to this one on http://www.diygokarts.com/vb/showthread.php?t=785.
Closed Thread
