Go Back   DIY Go Kart Forum > Building Plans And Advice > Mini Bikes, Trikes, and Choppers
Closed Thread
Old 10-17-2006, 09:05 PM
vetteguy112233 vetteguy112233 is offline
Junior Member
My tote goat is a homemade one, but has a 5.5HP OHV B&S motor that was purchased last year. It doesn't go very fast, I can almost outrun it by running beside of it.
The motor has a side mount shaft with a pulley bolted to it, a belt runs from that pulley to the rear axle on the left side, on the right side of the rear axle is a small gear with a chain that goes back to the large gear around the tire. The small gear is 2 1/2 inches and the larger one is 12 inches.
Is there anything I can do to the motor to make it faster? Or is changing the gears the only option. If it's a gearing issue, what size gears should I use?
Old 10-18-2006, 02:15 AM
cojaro cojaro is offline
The gear setup seems a little confusing. Maybe it's your wording, or that it's 3 in the morning, but yes, changing the gear ratios is about the only way to make karts go faster, unless you want to get a whole new engine. But 5.5hp seems strong enough, so your current gear ratio is probably what's holding its speed back.
Old 10-18-2006, 09:02 AM
jrjulien1 jrjulien1 is offline
ya i think its the gear ratio as well a 5.5 should go at least 25 to 30 mph
Old 10-18-2006, 04:34 PM
Junior Member
So I should change the 12" sprocket that sits beside the rear tire? If I put a 6" or 8" sprocket, would that help? How can I determine how much of a difference each size sprocket will make?
Old 10-18-2006, 07:54 PM
you should count the gear teeth on the sprocket on the engine and fill it in on a speed calculator as well as a 60 or 72 tooth gear for the gear on the rear axle {60 or 72 is the most common} and fill in the rpm for the engine if the engine is a honda fill in 3900rpm and if its a briggs and stratton or tecumesh then 3600 and if it sounds like a chineese/japaneese name its probably a honda knockoff and fill in 3900rpm the speed calc can be found here http://webpages.charter.net/jeffparker/speed_calc.htm alos youll have to fill in the tire size and only fill in the top row and all this will give you an approximate idea for how fast youll kart will go
hope this helps
Old 10-18-2006, 08:00 PM
oh srry i didnt notice that its belt drive so disregard what i said above however i suggest if its in your budget switch to a chain drive system as its more effiecient and will give you a more reliable and faster kart and as for the drive pulley i have an old pulley off of an old kart i had and its a little smaller than 7 inches however i never did get the kart up and running but the kart was run before i got it with the pulley so i would assume that it would work
hope this helps srry about the above post
Closed Thread
