Closed Thread
  #41
Old 11-10-2009, 03:19 PM
freakboy's Avatar
freakboy freakboy is offline
the names 'mater
You can definitly use the block as long as the bore aint scored like ****. is the crank good?
  #42
Old 11-10-2009, 03:23 PM
Rotore Rotore is offline
Teh SPIK
no the bore is perfect dude and i havent had enough time to inspect the crank but will do on thursday plus i found where most of the weight was coming from lol that steel flywheel is about 24lbs.
but i'll have to order pistons, connecting rods, piston rings, a new camshaft, exhaust valve and a gasket set which would be about $280 estimate
"No one is going to open doors for you your whole life, sometimes you have to open the dor yourself." Eddy
  #43
Old 11-10-2009, 03:38 PM
freakboy's Avatar
the names 'mater
OUCH! i would look at the local junk yard for a complete engine and then get the junk yard engine to run.
  #44
Old 11-10-2009, 03:52 PM
Teh SPIK
lol i can get the parts for free from my old shop teacher or take this time to build it up with aftermarket parts
  #45
Old 11-10-2009, 03:54 PM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is offline
Pro Junk Collector
For $280 u could buy a motorcycle engine. And trust me, it IS worth it.
"If you want, I can teach you how to make a bomb out of a toilet paper roll and a stick of dynamite"
  #46
Old 11-10-2009, 03:57 PM
freakboy's Avatar
the names 'mater
remember if its free its for me!
  #47
Old 11-10-2009, 03:58 PM
BriggsTwins's Avatar
BriggsTwins BriggsTwins is offline
yea really, i got mine out of a burned tractor for 40 delivered, unless you really want that sucker to run with some aftermarket parts.
two is always better than one! -Twin Coalition-
  #48
Old 11-10-2009, 04:20 PM
Teh SPIK
oh yea it's worth it when you see the power that can be made from this engine and besides im getting the parts for free from my old shop teacher i just got his call so YEAH!!!!!!!!!
and bad news i will end up building a rail instead of a reverse trike bmikarts doesnt have my parts in stock so cancelling that order.
  #49
Old 11-10-2009, 04:57 PM
modelengineer modelengineer is offline
Lord of the noise
Quote:
A mikuni on each cyl
Like a set of these...?
they're epic
Andrew
GS500F powered...
  #50
Old 11-10-2009, 04:59 PM
freakboy's Avatar
the names 'mater
what parts you need?
  #51
Old 11-10-2009, 05:02 PM
Teh SPIK
Quote:
they're epic
exactly what i was thinking dude
Quote:
axle, hubs, sprocket, clutch, bearingings, lock collars ect basically the whole rear end of a kart so i have to go cancel the order and shop around so instead of a reverse trike i'll make some kind of a rail/dragster type kart
  #52
Old 11-10-2009, 05:14 PM
heheh they are good engines.... ran the twin today, and she is just fine
  #53
Old 11-10-2009, 05:23 PM
Teh SPIK
Quote:
you should mod that engine and throw it on the kart
  #54
Old 11-10-2009, 05:27 PM
freakboy's Avatar
the names 'mater
Go with the reverse trike there cool as ****
  #55
Old 11-10-2009, 05:34 PM
Teh SPIK
really they are freakin awsome dude especially w/ a good engine
  #56
Old 11-10-2009, 06:33 PM
freakboy's Avatar
the names 'mater
yeah so just shop around alittle instead of changin ideas every 10 seconds lol.
  #57
Old 11-10-2009, 08:17 PM
this engine is going on a kart. i have a transmission thats going along with it. i am gonna find a yerf dog or equivalent and cut the rear off and build it up. i promised that twin a home and she IS GETTING ONE
  #58
Old 11-11-2009, 05:01 AM
Teh SPIK
lol i have to many ideas dude but ill jus go with a simple kart that you guys have on this site for now aiming for 31mph
what kind of tranny? BTW there are some twin brigs on hey mow going up to 11k rpm.
but i was wondering they make a connecting rod for the ch730 series engine thats .010 longer and was wondering if i could use it with the factory crank and wouldnt it give the engine a higher comp and longer stroke since its driving the piston up higher.
  #59
Old 11-11-2009, 09:38 AM
the trans is off the tractor i revived the twin from, 6 speed with reverse, and its a heavy mother. 11K on a twin.....scary...... and yes with a longer stroke youll get compression increases, but stuff specially sized especially billet rods is gonna cost u
  #60
Old 11-11-2009, 10:30 AM
Teh SPIK
stock rods are good enough for now dude
Closed Thread
