Go Back   DIY Go Kart Forum > Announcements & Suggestions > FAQ & Articles
Closed Thread
  #21
Old 07-15-2011, 12:10 AM
landuse's Avatar
landuse landuse is offline
Hi Birdbaja, welcome to the forums. You aren't doing anything wrong, you will probably find that it is your bent wheel that is causing the sticking. Soak it in some wd40 or something like that for a day or two.
Start a new thread and post some pics so that we can give you a hand
  #22
Old 07-26-2011, 08:43 AM
brandongeiger2's Avatar
brandongeiger2 brandongeiger2 is offline
Quote:
Originally Posted by Birdbaja View Post
can someone please shed some advice. I have an old go kart bought it early this noting. It needs new tires and rims. After I removed the nut and washer there is a key I'm guessing that it's to turn the wheels with the axle and not let the axle slip inside of wheel. My wheel was already bent bad so I tried hitting it with a 3 pound sledge hammer also put heat to It and also used liquid wrench. None has helped even budge the wheel off the axle. Am I going about it all wrong?
no you arent i had the same problem with my axle when i was gonna try to take it off i ended up cutting the hangers off and knocking the rest out with a 10lb sledge i still have the axle but everythings coldwelded on and rusted so goodluck.
Dirt Devil Build http://www.diygokarts.com/vb/showthread.php?t=15085
"YOLO"-Carpe Diem for the uneducated
  #23
Old 09-13-2011, 07:39 PM
Jeff Knize Jeff Knize is offline
Banned
Using enough lubricant for the axle will ensure that your go kart actually works properly. Many times your wheel won't spin properly simply because there is too much rust around the ball bearings of your wheel, which can often be cured by an application of WD40 or axle grease. It won't be the most pleasant job, but it should do the trick and help you to get your wheels working properly.
  #24
Old 09-13-2011, 07:52 PM
Doc Sprocket's Avatar
Sorry- WD-40 is not a suitable axle bearing lubricant.
  #25
Old 09-13-2011, 09:28 PM
machinist@large's Avatar
machinist@large machinist@large is offline
Quote:
The full original name of WD-40 is Water Dispersant #40; it was the 40th formula they came up with and tried. No where in it's name does it mention lubrication; it was never intended as such. It has it's place in your tool box, just NOT to replace oil as a lubricant.
  #26
Old 10-25-2011, 11:54 PM
paz paz is offline
paz
Awesome info..this is kinda how I learned how to skateboard.found people doing the same thing.learned who was the best.watched, practiced alot.then got better and better.sponsored.then taught newbies.we all started somewhere.you just figure out who's really kewl.and not.
  #27
Old 07-03-2013, 12:41 AM
BigThieme BigThieme is offline
Default Help on wooden frame chain saw go kart
So I have a wooden frame built and tires with a bike gear but will a 42cc chainsaw engine work if I weld the fly wheel on the clutch and be able to change my gear ratio
  #28
Old 07-03-2013, 12:44 AM
Quote:
I'd go with what he said
  #29
Old 07-03-2013, 12:46 AM
So how long do I wait
  #30
Old 07-03-2013, 12:48 AM
Ill check tomorrow
  #31
Old 11-17-2013, 09:17 PM
Man Bear Pig Man Bear Pig is offline
Junior Member
Sub'd
  #32
Old 10-24-2014, 03:10 AM
nixta nixta is offline
Your right very few people can drive fast cars well see........Click image for larger version
  #33
Old 10-24-2014, 04:00 AM
BirdFanatic BirdFanatic is offline
The missed Dirt track racers mini cups and a few others
  #34
Old 10-27-2014, 12:51 PM
lyfesaver lyfesaver is offline
Is there anything like this for the other Go Kart enthusiasts that have built their carts for off-roading (I do not mean dirt track)?
  #35
Old 10-27-2014, 05:20 PM
OzFab's Avatar
OzFab OzFab is offline
"This" meaning what exactly?
Closed Thread
