Reply
Old 05-08-2019, 06:35 PM
950speed's Avatar
950speed 950speed is online now
Default Yerf throttle cable!
Switching over to a ex17 Subaru on my Yerf dog. Well there are two issues
1. The end of the cable has a barrel on the end, and throttle lever has no way to attatch a cable like that.
2. The cable only has 1 inch of available room to move backwards and forwards.
(Neither picture is mine, but just used as a reference, red arrow shows barrel I was speaking if)
Any ideas as to what to do, I know I could buy a new cable, but Iím trying to use what I have. Ideas??
Old 05-08-2019, 09:27 PM
mckutzy mckutzy is offline
You can get a mountain bike universal length brake cable, cut off the ends and size to length...
Walmart and bicycle shops should have it...
Old 05-08-2019, 09:31 PM
950speed's Avatar
Yes but I wanted to see if there was a way to make due with what I already have.
Old 05-08-2019, 09:32 PM
Then cut it off...
Old 05-09-2019, 05:31 AM
950speed's Avatar
Yes, but still it is too short, does anyone have an idea for a “bracket” of sorts?
Old 05-09-2019, 06:30 AM
J.S.@SMS J.S.@SMS is offline
Here 8am-? Mon-Fri
Just get a new cable. I have used the ones from the local bike shop, and honestly I think that they're better than the go kart cables that I've used. I can get 8 or 10 ft for $10, and they have a barrel on one end and a mushroom on the other.
  #7
Old 05-09-2019, 08:20 AM
950speed's Avatar
I suppose I will do that because there’s no ideas, thanks guys!
Reply
