Reply
Old 05-06-2019, 03:33 AM
jonbenderr jonbenderr is offline
Junior Member
Default TC Belt Advice
Hello all!
So I just finished up installing a FNR box on my kart and my center to center distance from driver to driven pulley has changed to 7-3/8".
I have a 7" driven pulley. The original belt was a 203591.
The obvious choice now seems like it might be 203592. The center to center distance limit on this 7-5/16" to 7-3/8". So I would be right at the max which is what is causing some hesitation on purchasing.
The next step up, 203593, has a min/max center distance of 7-3/4" to 7-13/16.
Just looking for opinions on the matter.
Also, the following link from BMI is where I am getting these numbers...
https://www.bmikarts.com/30-Series-C...elt_p_999.html
Old 05-06-2019, 04:01 AM
itsid's Avatar
itsid itsid is online now
Nono, distances are meant "including"
so if the belt is meant to be for up to 7-3/8" CtC it's the one you want,
NOT the next size up.
PS diffeerent source: https://www.gokartsupply.com/tcbelts.htm
same result
Old 05-06-2019, 04:11 AM
Junior Member
Ok. Since the measurement was at the max of that range I was a bit concerned.
Thank you very much.
I will be sure to post here how I managed to get the reverse box mounted once I confirm that everything is solid!
Reply
