Closed Thread
Old 04-21-2019, 04:56 PM
Byronpen Byronpen is offline
Junior Member
Default Clutch always engaged. High RPM
Predator 212, jet upgrade new muffler, I cant bring down the ideal any more. it keeps the clutch always engaged. this is the second one. so there is no way its that part.
What should i do next. help me!!!!
Old 04-21-2019, 05:42 PM
950speed's Avatar
950speed 950speed is offline
Did you jet too rich and it’s acting as a partial choke? That will prevent it from idling all the way down
Old 04-21-2019, 05:50 PM
JTSpeedDemon's Avatar
2019 Build Off Winner!
Is your throttle cable too tight?
Currently Flathead-Crazed
Old 04-21-2019, 08:23 PM
Tpdingo Tpdingo is offline
If you can't get it to idle lower you can always get stiffer springs to increase engagement RPMs.
Give a wrench long enough and WD-40, and I can remove the world's rusty bolts.
Old 04-21-2019, 08:31 PM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is offline
Pro Junk Collector
If its idling to high, and your throttle valve is closing all the way, your mixture is too LEAN. this may be pilot jet or an air leak.
A rich mixture will cause stalling or low idle.
Old 04-21-2019, 09:36 PM
itsid's Avatar
itsid itsid is offline
Quote:
Sure,
thats like saying if you cannot turn the bedroom lights off you can always wear sunglasses in bed.
The Following 3 Users Say Thank You to itsid For This Useful Post:
950speed (04-23-2019), mckutzy (04-21-2019), pearl111 (04-23-2019)
  #7
Old 04-22-2019, 03:41 AM
anickode's Avatar
anickode anickode is online now
Do you have a return spring on your gas pedal, or are you relying on the throttle spring on the engine to do that?
Have you messed with the governor to make it go faster?
Does it still idle high if you unhook the throttle cable?
Is the gasket between the carb and engine damaged, or the carb bolts a little loose? A small air leak behind the throttle plate can sometimes make it act like the throttle is sticking open, causing a lean condition and high idle.
Etc etc.
It's called the diagnostic process. Everything that could possibly cause this to happen, especially to 2 motors in a row, must be considered, checked, and eliminated as a possibility.
"Well that would be a bomb."
The Following User Says Thank You to anickode For This Useful Post:
itsid (04-22-2019)
  #8
Old 04-22-2019, 04:50 AM
Junior Member
Thanks for all the areas to check out. all the areas that gave me information
  #9
Old 04-23-2019, 06:18 AM
Junior Member
Default Update
You guys . Had be take everything apart. It was me my throttle linkage was to short. . Made a new one good to go. Also. Is there a easy way to make this thing start really easy for my wife?
  #10
Old 04-23-2019, 06:27 AM
itsid's Avatar
Sure:
perfectly adjusted carb,
nice clean air- and fuel filter as well as spark plug
good compression and
ideally fresh fuel
it'll pop right at the first pull.. second in damp cold climate.
Or short: a well maintained engine
Other than that: not really I'm afraid..
it's more a good technique than strength that's needed to pullstart an engine.
slowly pull that thing into compression stroke, release rope, then give it a firm pull
and if your engine is well enough maintained it should start right up.
  #11
Old 04-23-2019, 08:52 AM
Quote:
HAHA!
I was RIIIGHT!
  #12
Old 04-23-2019, 08:57 AM
itsid's Avatar
Quote:
Originally Posted by JTSpeedDemon View Post
HAHA!
I was RIIIGHT!
OHOH!
He is ANNOOOYYYING!!
mckutzy (04-23-2019)
  #13
Old 04-23-2019, 08:59 AM
You're welcome...
The Following User Says Thank You to JTSpeedDemon For This Useful Post:
Closed Thread
