Reply
Old 04-13-2019, 08:20 AM
rpolanco rpolanco is offline
Junior Member
Default Centrifugal Clutch
What should I do to keep my clutch from sliding side to side on my Predator 212's crankshaft? I need it as far out as I can but I need it to stay in place.
Old 04-13-2019, 08:32 AM
bthompson224's Avatar
bthompson224 bthompson224 is offline
Should have set screws.
---------- Post added at 09:32 AM ---------- Previous post was at 09:31 AM ----------
http://www.diygokarts.com/vb/showthread.php?t=12328
Old 04-13-2019, 09:51 AM
mckutzy mckutzy is offline
Lets see some pics as to whats the issue???
How far over is it?..... It should be at the shoulder of the shaft...... If anything, you might need to move the motor or sprocket over....
Old 04-13-2019, 05:49 PM
950speed's Avatar
950speed 950speed is offline
If no set screws then: place washers/spacers between block and clutch as needed, then on the other side of the clutch place washers or spacers as needed, then put a bolt in the crankshaft, being a 212 there should be threads
Simple as that, but if you have set screws it’s less a hastle
Old 04-14-2019, 12:01 AM
J.S.@SMS J.S.@SMS is offline
Here 8am-? Mon-Fri
I have some 3/4 id tubing that I use to make spacers. Then I put a bolt in the crank to hold it there. Also, I’m just a little paranoid about having something spinning at 3000+ rpm held on by just a set screw.
Old 04-14-2019, 08:00 AM
With the chain on and at a proper tension.... its not going anywhere... set screw or no...
Bolt on the shaft is a good recommended step to maintain lateral clutch movement to a minimal..
  #7
Old 04-14-2019, 09:00 AM
950speed's Avatar
Agreed, I use spacers just to keep a little less stress off the chain!
  #8
Old 04-14-2019, 06:44 PM
That and sprocket wear.. Once it starts to thin out... the teeth will go to crap soon after...
Reply
