Reply
Old 04-03-2019, 06:48 AM
Llaslo12704 Llaslo12704 is offline
Junior Member
Default Manco 415 top speed
What do you think the top speed of a 415
With a 2.5hp Briggs and Stratton is?
Old 04-03-2019, 07:06 AM
landuse's Avatar
landuse landuse is offline
With a 2.5? Not much at all I'm afraid. It all depends on what gearing it has. It will have to be geared real low with that small engine, and that will naturally mean that it is going to be real slow too
Old 04-03-2019, 07:18 AM
Karttekk Karttekk is offline
Those karts shipped with either 5 or 6.5 HP engines along with 12 tooth clutches and 80 tooth drive sprockets. That combination should give you at least 25 MPH. Your 2.5 HP engine isn't going to do much for you. If you haven't bought the kart yet offer $50.00 less than what they're asking and put the difference toward a bigger engine.
Old 04-03-2019, 07:40 AM
Junior Member
Quote:
Yeah I will eventually
Swap it for a predictor 212
---------- Post added at 08:40 AM ---------- Previous post was at 08:34 AM ----------
If you had to guess how fast would you say with the 2.5
Old 04-03-2019, 08:13 AM
JTSpeedDemon's Avatar
Currently flathead-crazed
10 mph on the optimistic side?
Local Bird Engineering Nut
Old 04-03-2019, 08:48 AM
Junior Member
Quote:
It be used at the airport so that should be fast enough till I upgrade to the 212
How hard is it to swap the engine?
  #7
Old 04-03-2019, 08:53 AM
J.S.@SMS J.S.@SMS is offline
Here 8am-? Mon-Fri
5 bolts (4 mounting, 1 clutch), plus switching the throttle over, and you'll need a 3/4" clutch, a 2.5 horse likely has a 5/8" shaft.
The exact clutch that you'll need will be determined by the type of chain used, 1/2" pitch (40, 41, 420) or 3/8" pitch (35).
  #8
Old 04-03-2019, 09:19 AM
Junior Member
How much should the total cost be not including the engine?
  #9
Old 04-03-2019, 09:22 AM
Without:
Probably in the region of $20-$40.
With a stock Predator:
About $120-$140.
The Following User Says Thank You to JTSpeedDemon For This Useful Post:
Llaslo12704 (04-03-2019)
  #10
Old 04-03-2019, 09:24 AM
txluke txluke is offline
Pics!
  #11
Old 04-03-2019, 09:31 AM
Junior Member
It’s rough right now but will be painting it army green
And cover seat with brown leather
How do I insert photos without urls?
---------- Post added at 10:31 AM ---------- Previous post was at 10:29 AM ----------
Quote:
Originally Posted by txluke View Post
Pics!
Itís rough right now but will be painting it army green
  #12
Old 04-03-2019, 09:52 AM
Go to these little quick reply boxes, then click "Go Advanced".
In the top toolbar, click on the paperclip, and then pick your files from your PC in the popup window.
  #13
Old 04-03-2019, 10:14 AM
Junior Member
Could you just use the same clutch that is on the Briggs engine?
  #14
Old 04-03-2019, 10:20 AM
Nope.
212s have a 3/4" shaft, like most small blocks.
And 3/4 is NOT equal to 5/8.
The reason why we all gave pretty vague top speed answers is simply lack of details.
We need pics, what's your gear ratio, how big are your tires, and what's the fully loaded weight?
  #15
Old 04-03-2019, 10:25 AM
Junior Member
Nope.
Yes sorry for the lack of details
I just picked it up yesterday
And have only really looked at it for
5 minutes and wonít see it again till
This weekend
  #16
Old 04-03-2019, 10:28 AM
...wonít see it again till
This weekend
(Sad)
  #17
Old 04-03-2019, 11:53 AM
Here 8am-? Mon-Fri
I understand, I won't be able to work on my karts for a few weeks.
Reply
