Reply
Old 04-03-2019, 06:13 AM
vidaliaman vidaliaman is offline
Junior Member
Default my chain details, what sprocket?
well i bought a sprocket (2 1/8 diameter) for the jack shaft with a 1/2" pitch, three teeth of the sprocket fit in the chain but the teeth outside of that where too far for the chain. looking for the proper sprocket
here are my chain stats
pitch 1/2"
roller diameter 5/16
roller width 1/4"
pin diameter - between 1/8 and 3/16
link plate height - 7/16"
connecting width - 9/16"
not measured with caliper,
would you say i have a #41?
thanks
Old 04-03-2019, 06:49 AM
Karttekk Karttekk is offline
I'm pretty sure if you wire brush or clean both sides of your chain there should be markings stamped on it indicating which chain you have. Dave at Dave's Go Karts bailed me out on a similar question. #41 was stamped right on the chain itself.
Thanks
---------- Post added at 08:48 AM ---------- Previous post was at 08:46 AM ----------
See if this helps.
https://www.bmikarts.com/Chain--Purc...oot_p_635.html
---------- Post added at 08:49 AM ---------- Previous post was at 08:48 AM ----------
Scroll to bottom of page.
Old 04-03-2019, 06:59 AM
Junior Member
going to check out now, thanks
just checked, could not fine anything on any of the links, what i did find was next to the chain connector was a pin with a cotter pin also holding the chain together, this chain is in rough shape i think i will order new chain
thanks
Old 04-03-2019, 07:21 AM
Definitely grab a new chain and master link, otherwise that one will probably fly off on the first run or ruin something.
Reply
