Reply
Old 03-30-2019, 12:48 PM
Stinger Stinger is offline
Junior Member
Default Need drive wheel assembly help
Hi guys, I have a manco stinger kart (around 20 years old) just put a new predator 212 on it. the drive assembly threads broke it has a two piece rim that's threaded for the the bolts that hold the sprocket and brake on well the threaded holes have crumbled. couldn't find that style setup anywhere online. the tires are 145/70-6" #35 chain i plan to just go ahead and replace the sprocket and brake. I found a kit online $95 shipped but it comes with a tire ( I just bought 2 new ones) and shipping is super high any cheaper alternatives?
I hope i explained it well enough I'm not the sharpest about karts still learning
Old 03-30-2019, 12:57 PM
JTSpeedDemon's Avatar
Currently flathead-crazed
Says it all.
Local Bird Engineering Nut
Old 03-30-2019, 06:11 PM
txluke txluke is offline
Make sure the new rim isn't wider or you will need to weld a longer axle bolt like I am going to have to do.
The Following User Says Thank You to txluke For This Useful Post:
Stinger (03-30-2019)
Old 03-30-2019, 06:31 PM
Junior Member
I found this on gopowersports I believe it's exactly what i'm looking for
https://www.gopowersports.com/145x70...et-brake-drum/
---------- Post added at 07:31 PM ---------- Previous post was at 07:28 PM ----------
this is a small kart the back tires are 145/70-6" the front are 4.10/3.50-5". would it mess up gear ratio to put 145/70-6" on the front? it doesn't have suspension I'm thinking it would make for a smoother ride?
Old 03-30-2019, 07:40 PM
Front tire size has NOTHING to do with gear ratio! Put whatever size tires you want on there!
As for a softer ride, it's all relative with go karts!
If you want a softer ride without real suspension, taller tire sidewalls will help cushion.
The Following User Says Thank You to JTSpeedDemon For This Useful Post:
Reply
