Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Reply
Old 03-12-2019, 03:38 PM
Davefishman Davefishman is offline
Junior Member
Default Attaching a sprocket to a shaft that is fat on both ends.
I am new to the forum. I am trying to attach a sprocket to a shaft that necks down in the middle. This is an unusual shaft on a snowmobile. Each end of the shaft is about 0.97" inch but the middle is about 0.90". Here is a video to help describe the shaft
https://photos.app.goo.gl/tHz8q7UCydeRuYEh6
Thank you for your help.
Old 03-12-2019, 03:45 PM
JTSpeedDemon's Avatar
Currently flathead-crazed
Snowmobile?! WRONG FORUM!
Nah, it's cool.
What do you mean by 'necks down the middle'?
Do you mean a keyway? FYI that would be a notch in the shaft.
Local Bird Engineering Nut
Old 03-12-2019, 06:44 PM
txluke txluke is online now
Are you wanting to put a drive sprocket on the thinner part?
Old 03-12-2019, 08:14 PM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is offline
Pro Junk Collector
Ahh yamaha eh? You could cut the sprocket in half and weld it on...best bet would be to machine the shaft or use the original chaincase/sprockets.
"If you want, I can teach you how to make a bomb out of a toilet paper roll and a stick of dynamite"
Old 03-12-2019, 09:12 PM
itsid's Avatar
itsid itsid is offline
split sprockethub and a sprocket to mate with that!
Nosandwich (03-13-2019)
Old 03-12-2019, 11:17 PM
Junior Member
Yeah. I would like to attach a sprocket to the thinner section. Where would I find a split sprocket hub and a sprocket to match?
  #7
Old 03-13-2019, 03:08 AM
Nosandwich's Avatar
Nosandwich Nosandwich is offline
The REAL Poboy
Right about now, I miss that guy that used to post up these animated posts that had a cursor clicking on Google.
I do not recall Congressman.
  #8
Old 03-13-2019, 06:36 AM
landuse's Avatar
landuse landuse is offline
Quote:
You mean like THIS?
I know its not animated...
The Following 2 Users Say Thank You to landuse For This Useful Post:
Texan (03-13-2019), tgus3 (03-13-2019)
  #9
Old 03-13-2019, 06:42 AM
ezcome-ezgo's Avatar
What size sprocket are you looking for?
  #10
Old 03-13-2019, 12:13 PM
itsid's Avatar
Quote:
https://www.heeters.com/kartclutches.shtml
scroll down to the six spoke hub... looks to me it is a split hub
matching (coincientally) two piece split sprockets as can be found on that very same page
you can find various two piece hubbed sprockets as well..
like
https://cometkartsales.com/50mm-Stee...428-Chain.html
(the first match on google so maybe not the size you need)
but searching for "split hub" should find you some
As always:
do NOT weld to an axle!
  #11
Old 03-13-2019, 03:44 PM
Junior Member
And yet it was animated. Maybe you meant "polite" . . . It was not polite. For that matter it was not helpful or obvious since I had already done a lot of googling.
Quote:
Originally Posted by landuse View Post
You mean like THIS?
The Following User Says Thank You to Davefishman For This Useful Post:
landuse (03-14-2019)
  #12
Old 03-13-2019, 06:32 PM
Nosandwich's Avatar
The REAL Poboy
You mean like THIS?
Close, but his cursor would click on the Google search and pull up the answer, then he would say:"Was that so hard?"
Hmmm....Dave seems a bit high strung and pouty.
Reply
