Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Closed Thread
Old 12-13-2018, 06:35 PM
ilove2fix ilove2fix is offline
Default Can't find rims ? can i use same size all around?
hi guys i bought like 100 diff parts for $45 lol ... 4 of them are slicks 4.5x10x5
i cant find any rims? can i use them all around??
Old 12-14-2018, 12:47 AM
itsid's Avatar
itsid itsid is offline
..but no diff parts I assume
Well, you can if you like, but it's rather nasty to drive 10" wide slicks on the front I'd assume.
And you'll have to use wheelhubs, since for all I know there's no 9" front rim available.
(as a result the "front" wheels would awkwardly stick out)
ilove2fix (12-15-2018)
Old 12-14-2018, 05:22 PM
lol yeah tons of parts but no rims lol
There not 10" wide lol there 4.5" or 5" wide , hard to understand the print..
it s ays 4.5 / 10.0-5 ?
im assuming 4.5 is the width?
where can i find rims for these 4 tires?
Old 12-14-2018, 08:05 PM
itsid's Avatar
Oh.. soo 10 tall 4.5's for a 5 inch rim..
that'd be 10-450 x 5 then (10 inch tall 450 tenth wide, 5" rim)
4.5x10-5 is a race size (10" wide 4.5 segmented height five inch rim)
anyways.. good..
you'll need a ~4x5" rim (well every rim from 3.5 to 5.5 width will do)
Say the beloved Azusa TriStars http://azusaeng.com/product/test-wheel/
(maybe you want to add a spacer http://azusaeng.com/product/wheel-sp...uminum-wheels/ fits without looks better with a .5" spacer)
the awesome Nylites: http://azusaeng.com/product/5-azusalite-wheels/
or simple steel : http://azusaeng.com/product/5-multi-...-steel-wheels/
ilove2fix (12-14-2018)
Old 12-14-2018, 09:39 PM
thanks but cheapest rims are like $40 each �� im.looking for like $10 or $15 rims ? lol
Old 12-15-2018, 08:43 AM
itsid's Avatar
you see me baffled!
I mean 4.5/10.0-5 is not exactly identical to 4.5x10-5 (surely not math-wise LOL)
but that is confusing.
Anywho...
ther is no 10 dollar rim (used ones perhaps?)
Also this is a tubeless.. sooo a splitrim will need a gasket set.
Find used ones.
Any 5" kart rim (like you find on yard karts) will do,
manco, carter, kenbar, kartco... doesn't matter.. any such rim will do..
And if I see you ending up buying self-folding horror fraud wheels,
I will swing the ban hammer on you
  #7
Old 12-15-2018, 09:05 AM
lol
u said any 5inch wil do?
but this is 4.5 wide ?
dont i need 4.5 width rims?
  #8
Old 12-15-2018, 10:49 AM
itsid's Avatar
Nope, you'll need a rim that can take a tyre of that width.
it can be narrower (usually on yard karts that means a 3.5-4" wide rim)
or wider (usually on race karts that means a 5-5.5" wide rim)
it COULD of course be identical (a 4.5" wide rim) but it's not necessary to be identical.
But keep in mind.. it's tubeless (which brings us to race kart stuff)
soooo a single piece rim for tubeless tyres is recommended;
.. 5x5 isn't uncommon and should be easy to find; but that's front wheels...
IDK if you find a rear rims that size (and if you'll need maching hubs...)
hence my yard kart comment earlier,
since you'll find live axle, dead axle and fronts all the same size
rather easily.
but split rims need gaskets and some don't allow a tubeless tyre because of the valve..
so check that first
  #9
Old 12-15-2018, 01:58 PM
oh ok so one piece rim and i can use 5x5width or 5x4width rims?
will these fit my tires?
https://www.gopowersports.com/5-floater-wheel/
guys i think these tires are 4.5" rim ? or are you sure they are 5 inch ? can u believe i have no ruler! lol but it seems they are wider then the height of the hole.
  #10
Old 12-16-2018, 01:04 AM
itsid's Avatar
100% certain it's a 5" rim, yes
PS by the DR10 I assume you have Bridgestone tyres.. right?
So look at this chart:
Click image for larger version
ilove2fix (04-24-2020)
  #11
Old 12-16-2018, 09:27 AM
yes Bridgestone , oh ok so your correct 5 inch rim , will these rims do?
  #12
Old 12-17-2018, 04:44 PM
so what rims can i get? any links? im confused , u said i can use a 5 inch wide rims? even though its 4.5 " wide?
  #13
Old 12-21-2018, 12:11 PM
  #14
Old 12-27-2018, 05:52 AM
ezcome-ezgo's Avatar
Let me translate:
"You'll need a rim that can take a tire of that width.
It can be narrower (usually on yard karts that means a 3.5-4" wide rim)
it COULD of course be identical (a 4.5" wide rim) but it's not necessary to be identical."
The Following User Says Thank You to ezcome-ezgo For This Useful Post:
Closed Thread
