Reply
  #61
Old 08-20-2018, 06:36 PM
itsid's Avatar
itsid itsid is offline
uhh... a funny ugling.. I love it!
  #62
Old 09-24-2018, 10:51 AM
andrecht's Avatar
andrecht andrecht is offline
Jup, picture = me
Hyperdrive👇
Sent from my SM-G570F using Tapatalk
  #63
Old 10-06-2018, 02:24 PM
andrecht's Avatar
Jup, picture = me
Progress
  #64
Old 10-06-2018, 03:09 PM
Tpdingo Tpdingo is offline
Why say you can't have too much of something when you could say you can't have too much of everything. Too many wheels, too many sprockets, too much chain, too many fuel injectors, haha its beautiful!!
Give a wrench long enough and WD-40, and I can remove the world's rusty bolts.
The Following User Says Thank You to Tpdingo For This Useful Post:
andrecht (10-06-2018)
  #65
Old 10-06-2018, 06:22 PM
Kartorbust's Avatar
Kartorbust Kartorbust is offline
Man this thing is going to haul some serious tail! Probably hit around 25mph+, going to be one rough ride I'd bet.
Whatever I did, I DIDN'T do it!
The Following User Says Thank You to Kartorbust For This Useful Post:
andrecht (10-07-2018)
  #66
Old 11-21-2018, 11:33 AM
andrecht's Avatar
Jup, picture = me
Update..
https://youtu.be/8nv0KBsfnAY
  #67
Old 11-22-2018, 02:29 AM
landuse's Avatar
landuse landuse is online now
Quote:
Originally Posted by andrecht View Post
Update..
Looking awesome!! You are practically finished. Get the wheels on there now and ride the thing
The Following User Says Thank You to landuse For This Useful Post:
andrecht (11-22-2018)
  #68
Old 11-22-2018, 11:55 PM
Denny Denny is offline
All of the wheels are turning in the correct direction! You build some of the neatest stuff!
The Following User Says Thank You to Denny For This Useful Post:
andrecht (11-25-2018)
  #69
Old 02-07-2019, 10:55 AM
andrecht's Avatar
Jup, picture = me
New essential tool for the man cave...
I just couldn't see myself living another day without one...wink wink....
Way easier than it said on the box...
The Following 3 Users Say Thank You to andrecht For This Useful Post:
ezcome-ezgo (02-08-2019), karl (02-08-2019), landuse (02-10-2019)
  #70
Old 03-17-2019, 11:39 AM
andrecht's Avatar
Jup, picture = me
So a lot went down in the past month.
Im pushing to have this thing completely done by June this year.
After more than 6month debate, I finally ordered a full set of tires. Its been a major tossup between want/ need/ can afford...as it goes with any project.
I had to settle for the can afford option, seeing that I have 6 to buy
A set of 18-10-8 4 ply atv tires( can afford) would be on sale and became the deciding factor.
Ideally i would want 22-11-8 Kenda Bearclaw, as 22's will give more ride height and a softer ride but cost double.
Finished off the rollcage, and welded up an exhaust.
Welded up the seat frames, and mounted the frame on rubber bushes.
Next up will be the steering/ hydraulic components, and sorting out throttle mechanism.
Just a foot note.
Mounting tires onto rims is not nearly as difficult and intimidating as it originally seemed. Just use LOADS of soap!
The Following User Says Thank You to andrecht For This Useful Post:
ezcome-ezgo (03-19-2019)
  #71
Old 03-17-2019, 12:46 PM
Kartorbust's Avatar
She's coming along nicely.
andrecht (03-17-2019)
  #72
Old 03-18-2019, 12:25 AM
landuse's Avatar
Looking awesome! Whats are the 2 caster wheels for at the back?
  #73
Old 03-18-2019, 08:47 AM
andrecht's Avatar
Jup, picture = me
Quote:
The casters were attached to the frame prior to mounting the rims+ tires for ease of moving it around. I mounted the tires & rims without removing the casters. I couldn't bother to remove them before taking the maiden voyage.
The have been removed subsequently.
landuse (03-19-2019)
  #74
Old 04-01-2019, 10:43 AM
andrecht's Avatar
Jup, picture = me
So as suspected, the TAV20 is not capable of handling the low down power from the Diesel 450cc.
I now need to look at affordable alternatives to transfer the power to the centre differential.
My options are:
1) 40 series CVT
2)500cc - 750cc 4 stroke air cooled motorcycle engine via gearbox
3) hydrostatic variable gearbox connected to the existing engine.
Either way, I'm in for a pretty penny.
Option 1 is just unaffordable in this part of the world.
Option 3 is an unknown, but intend to pursue the option
Option 2 is the way my head is going, although availability of parts and quad carburetors have always been a headache.....
  #75
Old 04-01-2019, 11:18 AM
Kartorbust's Avatar
I would suggest maybe the Comet 44 over the 40. It uses a a larger driven pulley so it'll give you more torque (like you need any more lol). All the 40 series are rated up to 18hp. The 20 and 30 are only good to 8. The diesel, being the way it is has 10hp and something around 18 to 20lb/ft of torque, so that is another reason why the 20 series isn't lasting too long.
Another option is, get like a 4" pulley and run a kevlar v-belt to an 8" pulley to your differential. The v-belt will give you a bit of slip, but should be fine. You may need to run this setup in dual setup (dual pulleys).
andrecht (04-01-2019)
Reply
