Reply
  #41
Old 03-19-2018, 04:23 AM
andrecht's Avatar
andrecht andrecht is offline
Jup, picture = me
Quote:
Originally Posted by anickode View Post
The ARGO 8x8 we used to have at work had a Vanguard v twin with a torque converter driving a single FNR transaxle like you'd find in a John Deere gator, with an open differential driving the front set of wheels.
The rest of the wheels were all on stub shafts, Daisy chained together with sprockets and chain, each one driving the one behind it.
There was one brake on each side of the transaxle, operated independently by a pair of master cylinders attached to the control levers. Pull the right one to turn right, pull the left one to turn left, pull both to stop. Braking power, like drive power, was transmitted to all the rest of the wheels via the chains. If the chains broke (they never did as they were massively oversized) you still had brakes on the front wheels.
It did not have true skid steering where the two sides can be turned opposite directions simultaneously.
This will be very similar the the setup I intend to use.
Im on 1" Shafts as Axles & 08B or 1/2" Chain
Still need to source a trans-axle, but this is a "minor" detail..
  #42
Old 03-19-2018, 11:03 PM
andrecht's Avatar
Jup, picture = me
Some progress...
The basic chassis design, cut from 1/4" mild steel.
Wheel hubs & axle collars.
Sent from my SM-G570F using Tapatalk
The Following 2 Users Say Thank You to andrecht For This Useful Post:
ezcome-ezgo (03-20-2018), landuse (03-19-2018)
  #43
Old 03-19-2018, 11:43 PM
landuse's Avatar
landuse landuse is offline
Looking good!
The Following User Says Thank You to landuse For This Useful Post:
andrecht (03-20-2018)
  #44
Old 03-20-2018, 04:14 AM
andrecht's Avatar
Jup, picture = me
Quote:
Originally Posted by landuse View Post
Looking good!
Need to move this thread to build log?
  #45
Old 03-20-2018, 06:49 AM
ezcome-ezgo's Avatar
This is going to be great.
The Following User Says Thank You to ezcome-ezgo For This Useful Post:
  #46
Old 03-21-2018, 09:22 AM
andrecht's Avatar
Jup, picture = me
Suff happening in my workshop...http://cloud.tapatalk.com/s/5ab2786b...319_191457.mp4
  #47
Old 03-21-2018, 09:38 AM
Kartorbust's Avatar
Kartorbust Kartorbust is offline
Sprockets on top of sprockets, with a side of sprockets.
The Following User Says Thank You to Kartorbust For This Useful Post:
andrecht (03-21-2018)
  #48
Old 03-31-2018, 11:28 PM
andrecht's Avatar
Jup, picture = me
Standard 8" Golfkart rim & tire, this is 2 of 6. Golfkart rims are easily to come by, tires are interchangeable with ATV.
  #49
Old 04-08-2018, 09:37 AM
andrecht's Avatar
Jup, picture = me
Some materials arrived, and some progress was made...
Hollowbar 1"id 2"od
Collars for the wheel hubs
1" EN8 shafts
6 pieces x 400mm long axles
Bolts & Nuts
M12 40 HT + Nylocks...
Budget for the month spent..😣
The Following User Says Thank You to andrecht For This Useful Post:
ezcome-ezgo (04-09-2018)
  #50
Old 04-09-2018, 06:34 AM
Fantastic
andrecht (04-12-2018)
  #51
Old 05-01-2018, 03:13 AM
andrecht's Avatar
Jup, picture = me
More stuff to report..
ezcome-ezgo (05-01-2018)
  #52
Old 06-17-2018, 01:07 AM
andrecht's Avatar
Jup, picture = me
Evolution
ezcome-ezgo (06-18-2018)
  #53
Old 07-04-2018, 11:08 PM
andrecht's Avatar
Jup, picture = me
Question
Gear ratio:
Engine:
10HP 450cc Diesel
TAV30 10 tooth
Jackshift 57
Jackshift 20
Axles 25
Wheels 18"
  #54
Old 07-05-2018, 12:38 AM
landuse's Avatar
Quote:
Originally Posted by andrecht View Post
Question
Gear ratio:
Engine:
10HP 450cc Diesel
TAV30 10 tooth
Jackshift 57
Jackshift 20
Axles 25
Wheels 18"
Is it engine 10 going to JS 57 to JS 20 to axle 25? If so, that gives you a ratio of 7.125:1
I would definitely not go any higher than that. You could probably go a bit lower though. Your kart is going to be heavy. On the other hand, it IS a diesel engine which generally puts out a lot more torque
andrecht (07-05-2018)
  #55
Old 07-05-2018, 10:32 AM
andrecht's Avatar
Jup, picture = me
7.125:1 is what im aiming for.
I reckon the diesel should overcome the additional weight.
  #56
Old 07-29-2018, 11:18 AM
andrecht's Avatar
Jup, picture = me
Tapered crank shaft machined down to 3/4". Key way cut with a pencil grinder.
New 08B 10 tooth drilled, split and key way filed by hand.
Epic struggle to get the TAV2 30 mounted onto the diesel.
Had to re-tap all four mounting holes. Made a custom shallow tap to carefully cut new threads into the block.
ezcome-ezgo (07-30-2018)
  #57
Old 07-29-2018, 02:44 PM
anickode's Avatar
anickode anickode is offline
The thing you need for doing shallow blind holes is called a bottoming tap, FYI.
You get the threads started as best you can with a regular tap. Run it till it bottoms out. Then switch to the bottoming tap. It's basically just the full Diameter part of a tap, so the threads need to be started for it to work, but it will cut full dimension threads right to the bottom of the hole.
I always collect people's broken taps around the shop to make my own bottoming taps. Very handy.
"Well that would be a bomb."
The Following User Says Thank You to anickode For This Useful Post:
andrecht (07-29-2018)
  #58
Old 08-19-2018, 10:36 AM
andrecht's Avatar
Jup, picture = me
Chain tensioner
---------- Post added at 10:35 AM ---------- Previous post was at 10:23 AM ----------
https://youtu.be/U-Cn-9Y7wpU
Sent from my SM-G570F using Tapatalk[COLOR="Silver"]
  #59
Old 08-20-2018, 07:42 AM
Dang that's purdy.
andrecht (08-20-2018)
  #60
Old 08-20-2018, 11:18 AM
andrecht's Avatar
Jup, picture = me
Poncin, a obscure French company designed & built 66 and 8x8 ATV's in the 80's.
My aim is to build and open frame 2 seater ATV similar to the V2000s as shown in the attached picture.
ezcome-ezgo (08-20-2018), itsid (08-20-2018)
Reply
