Closed Thread
  #161
Old 09-06-2016, 11:15 AM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
Crank Gear side end to spacer gear
0.576"
  #162
Old 09-06-2016, 11:21 AM
bob58o's Avatar
Spacer gear thing thickness
0.1645"
  #163
Old 09-06-2016, 11:35 AM
bob58o's Avatar
Specs sent.
Think Predator 212 carb might be a nice upgrade for this Tec???
If I can find all of it??
And make it fit?
  #164
Old 09-15-2016, 11:25 PM
bob58o's Avatar
Hi Bob,
It looks like I have the right core for you. I have a few unground factory blanks from Tecumseh. Mine measures 3.805" long (the ends could be shortened if necessary) and the bearing journals measure .493". I would need to check the centerlines on your plastic cam since my blank has unground lobes. Let me know if you still want to proceed.
Thanks,
Tim
  #165
Old 09-16-2016, 12:21 AM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
Fantastic! I am doing a similar outsourcing for my Briggs Intek which is plagued by the dreaded plastic camshaft syndrome. Best wishes for a positive outcome!
  #166
Old 10-04-2016, 12:40 PM
bob58o's Avatar
Well trying to keep busy without spending money.
I cannot afford the new camshaft for this yet.
I did port the intake manifold.
There were some lips and ridges and I took care of it.
When I find the plastic cam, I will reassemble with no governor and the plastic cam and call it done for a while.
Pics to come when I get the better camera.
Closed Thread
